Heater will not shut complete off unless it's in pilot how do I fix this problem
  • Heating & Co... Master
  • 3,150 Answers
The gas valve is passing gas when in the off position unless you can access the gas valve it may need changing .
Posted on Dec 13, 2016
Why does the low battery light comes on shuts the heater down, but the battery has full charge? The model is 2300-700 this heater runs around 30 secons then stops?
Is this the European Fix ya? Nice to know the Mfr to know what is being fixed? If the low BATT light comes on I don't see why unless you just bought the battery you believe it is fully charged and is this a Battery Powered Tankless Pilot Light?
Sep 09, 2014 | Water Heaters
My mr heater wont stay light unless its above 3. It only stays on about 5 min then pilot goes out. It is gas heater. What's wrong with my heater?
Theres a thermostat inside, if its too cold and not warming up the thermostat enough it will shut off because it thinks there is a problem.
Feb 07, 2013 | Heating & Cooling
My pro comp heater will light the pilot but will not light the heater. It just sparks attempting to light, after a while it will shut off completely.
Could be your thermocouple. The spark should light the pilot and the pilot lights the main burner but if the thermocouple doesn't pick up the heat from the pilot the igniter will keep trying to light it until it times out and shuts off to prevent gas buildup.
Mar 10, 2010 | Procom MN300EPC Heater
Vent Free Blue Flame heater: shuts off
Sounds like a gas pressure problem. Have your gas company check the pressure.
Jan 31, 2010 | Procom (177653) Utility Heater
The pilot light blows out every time the main burner shuts off. It will light, the main burner comes on, everything seems ok until the main burner shuts off, then the pilot light goes off also as if the...
it's the thermocoupler ( about $20 ) that is bad replace it. if that doesnt do it it is the box with the on/off/ pilot button ( about $175 ) I found a complete unit at for $275 plus shipping ($300 total) and that is how i fixed the exact problem with mine.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
I just moved in. What happens when you shut the wall switch off.
If the wall control is the thermostat, then if you shut it off, your unit will not come on at all. If there is a pilot on your heater, it will remain on unless you shut it off at the gasvalve or gas shut off valve. Some heaters light themselves when they need to come on.
Mar 25, 2009 | Empire GWT-25 Wall Mounted Panel Heater
Sounds like your oxygen depletion sensor is shutting your unit off. The problem with fixing your unit is that it may cost you the same to purchase a new one (assuming you pay someone to fix it).
Feb 16, 2009 | Procom ML060HPA Heater
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jan 07, 2009 | Procom (177653) Utility Heater
My heater will not burn unless you hold the knob in once release it shut off
Are you getting the pilot light to work? some gas valves are finicky about where the knob is positioned when trying to light the pilot.
Dec 31, 2007 | Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
