Question about Sharp Televison & Video
My sharp lc=60sq154 tv. the picture flickers and has ghost images.
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
SOURCE: Sharp Aquos pictures problem LCD TV-LC-GA8E
I called Sharp and told them about our problem. At first they denied even knowing about this kind of problem but after some back and forth, they finally gave me a case number and told me to call back on Monday (this was on a Saturday). I did that and at first they didn't want to admit anything there either but again, after some back and forth, they agreed to have the set fixed by a local company (under contract with them I suppose). When the people called to tell us when they were coming we told them that they had told us that they would be there a few days later and the service people said 'yeah, but we got the part in sooner'. So what does that tell you? They do KNOW about this problem - it's just getting them to admit it. The service guy brought some new boards out but they didn't fit so they had to take the set in while they ordered new boards. That took almost 2 weeks but we've got it back now and haven't had any more problems with it. Our set was over 2 years old but I didn't know it at the time - I thought it was just over 1 year old. But we did give them the model and serial number and am happy with the way things turned out. We live in Texas so I don't know how anybody else's problems were handled.
Posted on Feb 17, 2009
rustym62
  • 201 Answers
SOURCE: My (sharp aquos lc 52d62u) tv fell to the ground. Image of broken glass and colored lines appear
Unfortunately the panel is cracked internally can't can't be repaired the whole panel has to be replaced. most times the panel will cost as much as you paid for the set. My son cracked ours when it was only 3 weeks old it doesn't take much force to ruin one.
Rustym62
http://www.the-tv-dude.typepad.com
Posted on Apr 26, 2009
dsacco86
  • 1077 Answers
SOURCE: My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
budmrtn
  • 11361 Answers
SOURCE: Sharp lc-32sh12u...no picture
It can be either the LCD panel driver board, or the worst case is bad LCD panel.
Posted on Nov 19, 2009
Testimonial: "Thanks for the response. I found a PWB board, a Power board and an AV board. Would one of these fix the problem?"
How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
Sep 13, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-70LE745U will not power on. Blink code is 2 long, 2 short. Tried the force power key sequence and the factory reset, but no joy!
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Nov 20, 2014 | Sharp Lc-70le745u
The picture of my sharp 42
Check its antenna orientation.
Sep 27, 2012 | Sharp LC42SB48UT 42 in. LCD TV
Sound good, no picture
Now turn on the tv? Have a flickers of picture a few sec. than dies have sound left only?Yes,than the long LCD inverter board it dead.This long LCD inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Aug 03, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
When tv is turned on picture flickers really
When it goes black can you see a ghost image? It will be a normal tv picture but very faint black and white looking, you may have to get close and look at an angle to even see it. If so that means your backlight system is failing. If you don;t see an image then it is a problem with the power section of the board inside the tv.
Check if it is covered by warrenty and get a quote if it isn't. A 42 inch is new and big enough that it should still be worth repairing but it may cost you anywhere from $100 to $250 depending on the shop to fix.
Apr 12, 2010 | Vizio GV42L 42 in. LCD Television
I have a sharp aquos tv. If i leave the tv paused, ie with a still image, for any length of time (20 mins for example) a slight image remains on the screen, even if you switch channels or switch off and...
Sharp does not build plasma tv's. Its an LCD and yes older LCD's do get burn-in also. Its not as bad as Plasma, it is a bit of a problem it ruins the LCD panel. If out of warranty when this happens turn off Tv and allow it to cool down a bit, if in warranty have the replaced the panel.
Hope this help
Jan 18, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
No Picture
If your TV is a SHARP LC-45GD5U,
Try using the reset buttons on the back of the TV. It should be below your digital audio output port.
If that doesn't work, ( this is only a guess) the power supply for the LCD screen may have burned out.
Feb 15, 2009 | Sharp LC-45GD5U 45 in. LCD Television
Flicker
I have the same problem when going to dark scenes from a bright scene or during channel changes. Sharp sent a tech under warranty and he installed new software to no avail. He called sharp tech support and they suggested turning on opc. The TV works fine but you must adjust sharpness and contrast to achieve an acceptable picture. I paid $868.00 for the set a Sam's club and will buy an extended warranty. I will not buy another sharp. My 40" sony works perfectly.
Oct 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
