Co znamena error E8 na pracke zo susickou gorenje wd 95140 What does it mean E8 error on the buckle of the dryer Gorenje WD 95140
SOURCE: No manual for Gorenje front loading washer.
Here is a link to the Gorenje website, you can download the manuals from there which explain all the symbols. This link is for the WA50140 machine which I have, just click on the 'manuals' tab
http://www.gorenje.co.uk/laundry/washing_machines?c=161105
Posted on Apr 28, 2009
  • 127 Answers
SOURCE: gorenje washing machine on display shows F31. what
it means"The connection to the tacho generator is open or short-circuited". that means the motor is not turning. 99% it is the brushes (20 eu) and it wil work again.
marko
Posted on Aug 13, 2009
SOURCE: gorenje WA72145BK fault 6 displayed on my LED
I have the same problem. Any solution? Thanks!!
Posted on Jan 09, 2010
jyackle5
  • 8197 Answers
SOURCE: how to operate dryer on the LG WD 14700rd
You may download the manual on link below.
http://www.lg.com/lgecs.downloadFile.ldwf
Good Luck and please rate 4 thumbs for the free answer.
Posted on Apr 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: Gorenje WA132 F2 error
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
I have just moved into an Apartment with a Gorenje wi 62112 Washing machine, I have no manual Can anyone tell me what the numbers on the Dial mean What should I choose for a general wash.
Gorenje has some documentation for their washers here: http://www.gorenje.com/simplicity/en/washing_machines/simple_manual_for_washing . The numbers indicate the water temperature (in Celsius) for a given cycle. The common choices are a cottons load in hot water (60 degrees). This is great for towels and other whites. The mixed load is for permanent press that can be in warm water (40 degrees). Then there is a cold water cycle for delicates (30 degrees). However, you should check the fabric care label before choosing the cycle.
I hope this helps.
Apr 20, 2016 | General Washing Machines
Gorenje Gv63320
It could be main motor or main control board problem It seems like main motor pump or main control problem
do step by step troubleshooting procedure to eliminate working parts until you could detect defective part or parts
Dec 09, 2013 | Dishwashers
Gorenje dishwasher e1 error
I know that this is an old topic but I have exactly the same problem. Did you manage to fix it?
Jan 26, 2013 | Gorenje GV 62110 23 in. Built-in...
Need a Gorenje WA61111 Manual
the manul is here in pdf form:-
http://www.gorenje.co.uk/support/manuals?t=instructions&cm=wa61111
Dec 20, 2012 | Washing Machines
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
Gorenje B 8960 W, shows blinking times only, not
Same problem, anyone knows how to fix it?
Dec 31, 2009 | Gorenje Refrigerators
I have a Gorenje fridge freezer New Line bought in 1990. The fridge door compartment rails are cracking how can I get spare parts?
I found them in Bosnia, where New Line gorenje was made in 1990. Thank you for posting my problem.
Jul 06, 2009 | Gorenje Refrigerators
Jan 27, 2009 | Washing Machines
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
