Question about Universal Televison & Video
Codigo para programar caja de cable dish con control universal trisonic TS-RC411 Code to program cable box dish with trisonic universal control TS-RC411
    Top Expert:
  • Universal Master
  • 75,476 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Dec 16, 2016
Como puedo programar el control de la Caja de dish network para que apague mi tv lg
Luis, mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Es un placer poder asistirle. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales sientase libre de contactarme directamente a: kimberly.escobar@dish.com
Kimberly.Escobar
Social Media Representative
DISH L.L.C
Aug 24, 2013 | Televison & Video
Como enlazar un control remoto IR 103602 con una caja receptora DishDVR510
Juan Carlos Hola, se que ha este punto quizas no necesite asistencia con la programacion del control. De todas maneras le dare los pasos a seguir en caso de que los llegue a necesitar en un futuro. Para programar el control de DISH Network a su recibidor puede seguir los siguientes pasos: primero debe de accesar la pantalla de System Info esto lo puede lograr con tan solo oprimir el boton que dice System Info enfrente de su recibidor. Una vez este la pantalla de System Info tome su control y oprima el boton se Satellite por 5 segundos hasta que todos los demas botones se iluminen en rojo una vez esto suceda oprima el numero 8 seguido por el signo de numero (#) y despues boton de Record 3 veces. El control deberia de funcionar, puede intentar su funcion oprimiendo el boton de Cancel esto deberia de llevarlo de regreso a su programacion. Puede usar este link que tambien le puede servir mucho en como arreglar su control y los pasos seguir http://www.dishnetwork.com/SupportSection/remote-control
Nov 20, 2012 | DISH Network IR Remote Control
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
May 12, 2011 | DISH Network IR Remote Control
Mi caja convertidora es zenith y quiero programar el control de la caja convertidora con mi television zenith
como puedo conseguir el control remoto de mi caja covertodora se me descompuso y no puedo programar mi senal
Jan 30, 2011 | Abt Television 1745 Remote Control
Como programo la caja del dish
Hola mi nombre es Mayra Diaz con DISH Network con mucho gusto le puedo ayudar a programar su caja de DISH. Si por favor me puede dar mas detalles de lo que pasa como el modelo de la caja, es un recibidor nuevo? Ya teniendo estos detalles le puedo asistir con un mejor conocimiento.
Aug 04, 2010 | DISH Network IR Remote Control
Televison & Video Logo
116 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
