Question about Garden
Where is the idle screw on Sym Jet Euro 50?
When I start up my Sym Jet Euro 50 it, the motor eventually stops running. I need to adjust the idle screw, I have been told where it is, but I am not sure I remember.
    Top Expert:
  • Garden Master
  • 77,932 Answers
It is on the carburetor.
Posted on Dec 11, 2016
My sym 50 keeps back firering and cutting out when it's hot what's wrong with it
Hi, Lorna and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Major missing backfiring cutting out when hot
starts runs backfires dies CDI ruled out
Sym Jet 50 Service Manual
Sym JET EURO EU2 50 cc 2004 Parts
Sym JET 50 series Owner Manual
Sep 09, 2017 | Sym Motorcycles
At what rpm should my 2008 Sym Jet Euro X 50 start moving?
it should start feeling like it wants to move about 300rpms above idle
contact a service dealer for exact rpms that it will be fully engaged
Oct 17, 2015 | 2008 Sym Jet Euro X 50
Sym jet euro I have cleaned the carb put back together it starts at fast idle then settles down then stalls take the plug out and is wet with fuel so I am confused can some one please help me
take carb off again and check float height it should be 8.8 +- 1mm then screw air mixture screwin untill it just seat the unscrew 1 1/4 to 1 1/2 turns once running set idle to 2000 +- 100 for the 50 and 2100 +- 100 for the 100 model
Jul 22, 2014 | 2004 Sym Husky 125
Need to adjust the spark plug gap/change and also push Air screw 1/2 thread inside in the carburator
Nov 08, 2013 | Sym Motorcycles
Strating PROBLEM
Hi, Andrew and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Why won my SYM Jet motor scooter start
Scooter Troubleshooting Scooter won start All about Scooters
SYM Sanyang Scooter Parts Racing Planet USA
May 09, 2017 | 2007 Sym Jet Euro X 50
Sym jet 100 no power
hi i got a sym jet euro x 50 there is no electrics working at all u can ride bike but u have to kick start it but no brake lights or horn indicators nothing whats best way to go about it
Feb 17, 2013 | 2007 Sym Jet Euro X 50
My sym jet sport x has no power whats wrong with it
with bairly any power it might just be you air and petrol mixture or to much two stroke if it is a 2 stroke either that or whiring problems it is common with sym mine has problems with wiring too !!! :)
Aug 23, 2012 | 2007 Sym Jet Euro X 50
I have a sym 100 Euro jet that will not start in the cold
if real cold wheather the oil is thick and will make starting sluggish, or not at all.
it takes alot of cold cranking amps to start a cold motor. you could probably jump start it with a battery charger that has 50 amp start option.
if you think its carburation.........your automatic/manual choke may not be working, check cable adjustment, and lubricate your cables.
you can pull the choke out and clean it.
Dec 08, 2010 | Sym Husky 125 Motorcycles
Hi i am having problems with my SYM jet 50 euro x, i have had a new battary about 1 month ago and i have had my carb cleaned but i still having some problems with the lights going dull and when i am riding...
Hi, Aaron the answer to all these questions is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
SYM Jet Sport S50 Service Manual
SYM Jet Sportx 50
Sym Jet Euro Wikipedia
Aug 20, 2017 | 2007 Sym Jet Euro X 50
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
