Question about Kitchen Appliances - Others
Need wiring diagram for red head dehydrator it want heat up
    Top Expert:
  • Kitchen Appl... Master
  • 40,500 Answers
Request the diagram from Red Head.
Posted on Dec 12, 2016
Food dehydrator heat not working
What is the make and model please, some dehydrators only have fans and no heating element.
Here is a link to the manual which has a phone number to call if you still have problems:
Feb 20, 2017 | Kitchen Appliances - Others
Color code for theromstat
Wiring Examples and Instructions
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
I have a LEM 778 10 try stainless steel food dehydrator the machine when running runs okay until the end when product is almost dry then the fan motor turns off and still hear the motor running. Heat and...
Most of these stainless dehydrators have a cheap timer which uses plastic gears turned by an electric motor to operate the machine. After being on for a while the whole timer will heat up and the gears unside will begin deflecting and failing. When this happens the only thing to do is wait for it to cool down and see if it works again. Eventually it will fail completely and the machine will jus tstart shutting down halfway through cooking.
It is possible to bypass the timer and use an outlet timer, but each model of machine is wired slightly differently. You would have to consult a knowledgeable electrician.
There are newer models on the market which have digital timers. These work muuuuch better, but the fa
Jan 10, 2014 | LEM Products lem Stainless Steel...
I am looking for a wiring diagram for a nesco food dehydrator fd-61
Such devices are so simply built that it should not require a wiring diagram. Did you blow a component? If it does not heat up look for a thermal cutoff.
Oct 04, 2013 | Kitchen Appliances - Others
What is a Food Dehydrator?
Wikipedia says: a food dehydrator refers to a device that removes moisture from food to aid in its preservation. A food dehydrator uses a heat source and air flow to reduce the water content of foods.
Feb 18, 2013 | Kitchen Appliances - Others
Wiring Diagram for Nesco FD60 Dehydrator
There is a recall on some of these. Check it out here:
It has to do with something overheating. Maybe your unit is covered...
Apr 27, 2010 | Nesco Gardenmaster Digital Food Dehydrator
I need to rewire the hydrator and need diagram to complete the wi
1st -If you don't see how you can hook up 5 wires with 3 caps - you're forgetting the household cord wire.
How to wire it correctly:
This is how mine is wired (same brand perhaps a different mode)l:
1. Connect one side of the household current (big white wire) to the part going into the knob for the temperature control (the rheostat )
Put on one of the twisty plastic caps.
- Now variable current is going into the heating elements.
2. Find the two wires coming out of the heater part.
One carries the juice, the other goes back to complete the circuit.
(Red & black are always IN current - white & blue are always return wires to complete circuits coming OUT of a device)
3. Connect the black motor wire to the red (juice carrying) wire from the heater. (put on a twisty cap) Now you have variable current going INTO the fan.
4. Connect up the rest to the other part of the big white plug to complete all the circuits. (should all be white or blue) Put on a twisty!
You're done. When testing be sure to not let the elements touch the plastic they can melt and stick to it very quickly.
How to bypass the switch if the motor isn't working:
I would NOT recommend doing this for the heater element. You might cause fire.
note: I had to bypass the rheostat for the fan because it was putting out enough current for the motor and the heater.
In that case I only need two twisty caps.
Just hook the motor up directly with the juice going before the rheostat and then the rest of the outgoing circuits to the other return wire of the household electric cord.
Now I vary the temperature but fan will run at a constant rate.
Apr 25, 2010 | Nesco Gardenmaster Digital Food Dehydrator
Hi I purchased a Nesco food dehydrator at a yard sale and need a manual for it . Model fd60, can I print one off the internet for this model?
I would think that any dehydrator information would work for you.
You just have to be sure the components are working (ie. fan and heating coil.) A dehydrator is pretty basic. here is a link for books on a site that sells the product.
You can find a lot of books at the library too.
This might also help, dont let the name fool you:
With some searching on line you will be able to find a lot of instructions and probably even ones for your specific dehydrator.
Look on forms about drying foods and ask for the basic instructions if you find you really need them after looking at the links above.
There might be someone willing to scan them and email them to you.
Dec 15, 2009 | Nesco Crock Pots & Slow Cookers
Take apart the bottom unit that contains the heating element. Hopefully it's put together with phillips screws. Mine are not. I'd have to drill out the brads that are holding it together. Once it's apart, use an Ohmmeter to check the heating element. Be sure to disconnect the fan from the heating element when ohmming out the element. If the element is open electrically, replace it. Good luck in finding a place to purchase a new element.
Sep 12, 2009 | Nesco Gardenmaster Digital Food Dehydrator
I need a wiring diagram for a 1999 Jeep Grand Cherokee
Here is the stereo wires which may help you figure out which are not the ac wires etc. hope this helps with some of the problem.
Constant 12V+ Red/White  Switched 12V+ White/Red  Ground Black  Illumination n/a  Dimmer Orange  Antenna Right Front  Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red  Left Front (-) Light Green/Green  Right Front (+) Light Blue/Red  Right Front (-) Light Blue/Black  Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White  Left Rear (-) White/Dark Green  Right Rear (+) White/Purple  Right Rear (-) Tan/Dark Green
Nov 14, 2008 | 1999 Jeep Grand Cherokee
Kitchen Appliances - Others Logo
59 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
