Question about Hitachi Televison & Video
How do you change bulbs on a Hitachi UltraVision 53SBX59B
  • 1039 Answers
SOURCE: Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Posted on May 02, 2009
  • 72 Answers
SOURCE: hitachi ultravision 2005 turns on for about 5
could be shoted convergence ICs
Posted on Jun 07, 2009
tvtek
  • 1284 Answers
SOURCE: I have a 60 in hitachi ultravision projection tv.
Make sure the lamp is seated all the way in. You also want to make sure the lamp door is placed back on the TV so it can activate the saftey switch in the TV. If those fail try unplugging the TV for at least 2 minutes then powering it back up again. Please take a moment to rate my answer. Thanks...
Posted on Nov 23, 2009
SOURCE: green bulb-or lamp on ultravision hitachi 57uwx20b
I have a 60" Hitachi Ultravision that just stopped displaying picture and sound. Until that point it was in excellent shape. I am suspecting an IC or a resistor going bad. Any one is welcome to pick it up from my house (NJ) for $50, to fix it or for parts. call 609-613-1644.
Posted on Jan 18, 2010
SD Tech
  • 14553 Answers
SOURCE: Hitachi ultravision 50V500A screen dim
The model indicated is a DLP rear projection and uses a "lamp" for brightness.
If it has not been changed for a while it should be on the right side of the set behind a removable plate. Check your owners manual if you have it.
Life span varies but 2,000 hours is normal.
Let me know if you need any further assistance as I am here to help.
SD TECH
Posted on May 14, 2010
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
I want to remove the screen from my Hitachi Hitachi 53SBX59B 53-Inch UltraVision Projection TV to clean the lamps and mirror. I took the speaker cover off and then removed about 9 screws. I tryed to pick...
I believe on your model the front lower speaker grille pops off, then you will see 4 phillips head screws holding the frame on at the bottom. After the screws are out have someone hold the other side while you using your hand tap upwards from the bottom of the frame evenly on both sides. The frame slides onto slotted brackets on both sides. The frame will lift off, if your control button harness is still attached just set the frame so it is out of your way and not stretching the leads. Clean the mirror with windex and a soft cloth, same with the 3 crt's. If that model has a foil type mirror then be very gentle with it. Don't worry if the mirror has a few streaks left over they wont interfere with the quality of the picture..After reading your post again, sometimes they are buggers to pop upwards.
Nov 27, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I have a 53" Hitachi Rear Projection TV, Everything works except the color. The 3 color projection lamps are functioning and all of the tv's focusing features appear to be functioning as well. It has a...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2010 | Hitachi 53SBX59B 53" Rear Projection...
SD TECH
May 14, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi ultravision tv
tv comes on ,i hear but can not see
Dec 27, 2007 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
