What size propane tank do i need for models PF06YJLFB and PF06YJLFB
  • Heating & Co... Master
  • 3,182 Answers
Whats the btu's??
Posted on Dec 13, 2016
I need to know the propane orifice size for a Peerless LUH50A hanging heater When running the unit on a regulated propane tank the heater emits black smoke
ask a qualified gas fitter for the correct jet size and have him position the air shroud correctly to get the correct air /gas ratio for a clean burn
Jan 29, 2017 | Heating & Cooling
That may well be soot its not burning right turn off and do not use . co2 coming off the heater needs a service asap .
The tank size dosn't matter all you need is a feed line This looks like a spicific tank appalaction but just feed it remotely with a normal propane tank and a feed line and save your self the head ache as long as it dose what you want it to do ist cool
Mar 06, 2012 | Mr. Heater Thermocouple
What size propane tank do i need with a Mr. Heater 45,000?
Rule of thumb is that you have 100,000 btu's per gallon of propane. This only translates into the length of time you have available in a tank of gas. The problem arises when you consume too much too fast. The gas can't produce enough vapor to continuously run and becomes dormant which is commonly known as "freezing up". You can use a typical (20 lb.)5 gallon propane tank (barbacue size), but it will more than likely freeze up in 2 - 3 hours of continous use. I'd suggest going to the next larger size a 30 lb. or 7.5 gallon size. The best way to work this system is to have two 5 gal. tanks so you can switch one out when it freezes and let it thaw while your using the spare.
Oct 04, 2010 | Mr. Heater Natural Gas Garage Heater -...
Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Jan 05, 2010 | Desa International TB101 Heater
I have an older Genesis grill with a leaking regulator
You can get a replacement regulator at just about any home improvement store (Home Depot, Lowe's, etc.) There haven't been changes in the size of the ports or thread patterns on regulators or propane tanks in the last 15 years.
Oct 07, 2009 | Thermos Stainless Steel Gas Grill
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
Procom ML300TBA Heater: Liquid or Gas
Propane exist in a liquid state when it is under pressure in a propane cylinder. When the valve on the propane cylinder the pressure on the liquid is reduced and the propane reverts back to gas state.
Also, regarding the tank you need....
the owners manual probably states what size you will need but, with most heater like the one you have it will require a 100 lb tank (approximately 25 gallons). You will also need an inline regulator set to 11" to 14" of water column between the tank and the heater.
Jan 09, 2009 | Procom ML300TBA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
