Question about Dryers
HLP140E Why would the dryer be vibrating loudly during operation?
  • 65 Answers
SOURCE: Vibration
Normally, I find lint stuck in the fins of the blower that cause it to vibrate. remove the front panel to access blower.
Posted on Jan 27, 2009
  • 531 Answers
SOURCE: Refrigerator motor vibrates loudly during temp change/running
open the back and check see were the noise comming from be fore call ing service you may have compressor problem
Posted on Apr 07, 2009
SOURCE: very loud vibration during the spin cycle, how do you control this only 2 wks old
check the inside of the machine (have to unsrew the top of the machine)each corner should have a rod wich the drum balances on perhaps one has come loose or a spring is gone. possible lol i hope this is some help to you
Posted on May 05, 2009
SOURCE: Ventilation question regardingHAIER HLP140E
Hi I own this dryer and you have two choices for venting it. One reason I originally bought it is because you can run it safely without venting it to the outside. That's a huge plus for many small apartments or a dorm room etc. For that option you purchase a 'ventless' kit from Lowe's or Home Depot, can't remember the exact cost but definitely less than $20. It works very well, but will add some heat to your living space (nice if you're in NY, less nice in Miami). It didn't add a lot of heat to the space, but later on I ended up installing a vent through the outside wall (which was much easier to do than I thought) because I was doing some drywall work in that area anyway. That vent is also very inexpensive, maybe $10. The standard vent kit opening will be for 4" whereas this dryer's vent opening is 3" - but the dryer comes with a piece that makes the 3" to 4" transition for you. This is a very convenient unit because it only needs 110v (standard household outlet) instead of the usual 220 (or is that 240?). The main thing that will help you be happy with it is just to have the realistic expectation that it takes about twice as long to dry clothes (60-90 min) because it's on lightweight power. But it does a very nice job, and we love the little washing machine we got with it too!
Posted on May 29, 2009
  • 7482 Answers
SOURCE: High-pitched squeaking during operation
Your problem sounds like drum rollers may be in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on May 27, 2010
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Making loud noise
The drum rollers or idler pulley/belt would be suspect. The link above will help on all makes and models.
Oct 19, 2017 | Haier HLP140E Electric Portable Dryer
There is a loud rumbliing sound that seems to be coming from the motor (haier hlp140e) it's ability to heat also seems diminished. The rumbling used to happen on and off, but now it happens all the...
sounds like bearing noise and drum hitting on inside of outer body - naturally the drying process will be somewhat diminished and eventually the whole drum will compromised and collapse . Advice is to purchase a new dryer .
Jul 25, 2011 | Haier HLP140E Electric Portable Dryer
I own a dryer model #HLP140E and I need to buy a replacement filter that fits inside the unit. Please direct me to wear I can buy replacements. Thanks!
May 22, 2011 | Haier HLP140E Electric Portable Dryer
Frigidaire dryer FERB5700DS0 loud vibrating noise when heating up and gets louder during use
drum glides, drum rollers or idler assemblage which is next to motor. This website will explain how to open dryer and the glide/rollers, Tim:
Nov 27, 2010 | Frigidaire Dryers
Haier HLP140E Electric 110V dryer exhaust filter.
I have had this dryer for 4+ years and finally have used the "floor vent" filters that come 12" x 4" and cut two of them to fit. It's a pain because unlike the round design they can "fall out" when you snap the filter back in. Be that as it may, they work well because you cannot buy the black round wool filter anywhere.
Jan 03, 2010 | Haier HLP140E Electric Portable Dryer
Jan 27, 2009 | Hotpoint NVL333GY Gas Dryer
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Dryers Logo
26 people viewed this question
Top Dryers Experts
