Question about Vtech CS6199-4 4 Handset Cordless Phone with Caller ID/Call Waiting
How do you turn the display light up brighter so you can see it!!!!
Vetch CS6199-4 model
How do I take mute off my vetch Han
If it is like mine, you have to first be on a call, then press the mute button. That turns it on. Then press it again. That turns it off and the screen displays "microphone on"
Jul 08, 2017 | Lands Phones
My vetch phone shows "new voicemail". how do I delete this
To clear the "New Voicemail" display from the handset
is a slightly different procedure for each model of cordless
phone.
Try the following (tested on my own cs6229 phone):
press [menu]
scroll to "Clr voicemail"
press [select]
display reads "Turn Off Indicator?"
press [select]
phone will (chirp) press [off ]
Or, this one (tested on my own cs6114 phone):
press [menu]
scroll to "Settings"
press [select]
press [select]
display reads "Reset VM Icon?"
press [select]
phone will (chirp) press [off ] [off ]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
Feb 13, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
How do you make the number that tell time light up darker so you can read it.
If you want to make the display brighter (remember, it auto dims in low light):
1. Hold down the "clock set" button while pressing the "volume" button up or down (up for brighter, down for dimmer).
Jun 10, 2014 | Bose Wave Radio
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
I need to know how to set up my vetch answering machine on my vetch phone
Enter the model of your VTech system into the box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Aug 15, 2013 | Vtech Lands Phones
I have a CDA 7892 alpine works great but would like the display to be brighter seems a bit dim manual does not say this model can be adjusted or am i missing it any help thanks in advance
You didn't specify if you wanted the display brighter in the daytime while headlights are off or if it is too dim when the headlights are on, with respect to the rest of the instrument panel illumination. Too bright is easier to deal with but too dim is tough. If it is always too dim under but daytime and night time conditions the only way to improve brightness would be to very gently disassemble the front panel (easier if it is the removable type) and determine what provides the back lighting. If there are tiny LEDS you could painstakingly add more LEDS or swap them out for brighter LEDS. There could be a lot of guesswork determining if this or that LED was brighter than what is in the unit as built. It may just be easier to live with it as-is.
Mar 26, 2011 | Alpine CDA-7892 CD Player
The time display numbers are very dim and I can hardly read them.
There are two main causes for this dimming:
1. Dust & other particle buildup on the front of the display glass and the rear of the display window. This can be cleaned.
Cleaning the display is easy, but you need to be careful so you don't break the glass.
First you would unplug the microwave or turn off its breaker.
Then see the video here that shows you how to remove your control panel assembly in less than 5 minutes.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the plastic frame.
Then carefully (since the display is made of glass) remove your circuit board.
Using a soft cloth (since paper towels can scratch) lightly dampened with non-ammonia cleaner (since ammonia can damage some polycarbonate plastics), gently wipe off the front of the glass.
Then gently wipe off the back side of the plastic display window in the plastic control panel frame.
Reassemble, reinstall, and power it up, and it should be brighter, sometimes a whole lot brighter!
If that does not brighten it up enough, then...
2. Your vacuum display tube is wearing out and either the VFD display tube or the whole control circuit board must be replaced, depending on your model number, which you didn't mention.
If you'll contact me with your model number, I can give you an estimate and free do it yourself info.
Aug 21, 2010 | Sharp Microwave Ovens
WHAT IS THE BULB NUMBER FOR THE BRAKE LIGHT ON 2005 TRAILBLAZER
2005 CHEVROLET Trailblazer
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006EB EcoBright - Your Environmental Choice
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005EB EcoBright - Your Environmental Choice
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
3757ALL
Front turn signal
3757ALL
Rear turn signal
3157LL
Tail light
3157LL
Stop light
3157LL
High mount stop light
Assembly
Fog/Driving light
880
880ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
893
893ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
3157LL
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
194
Map light
194
Dome light
212-2
Step/Courtesy light
194
Trunk/Cargo area
212-2
Nov 19, 2009 | 2005 Chevrolet TrailBlazer
Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Jan 06, 2007 | Frigidaire FEF326 Electric Kitchen Range
Vtech CS6199-4 4 Handset Cordless Phone with Caller ID/Call Waiting Logo
46 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
