My gas fireplace pilot will light and stay on but when I turn on the main switch only about 4 holes on each side of the pilot will light. It will not light the rest.
  • Heating & Co... Master
  • 3,182 Answers
I would check and see if the holes in the burner are not blocked , Could need cleaning.
Posted on Dec 11, 2016
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
? 0:16
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
Nepolean fireplace wont come on when switch turned on. pilot works fien
I have a Monarch fireplace (LP). Each year I have to take a can of computer cleaner "air" and spray out the oxygen sensor located near the pilot light. If dust or a spider blocks this oxygen sensor, the unit will NOT turn on. The pilot lights but the rest won't start. You can also contact your local gas company and ask where yours is located on your unit.
Jan 27, 2015 | Napoleon Fireplaces Main Burner Orifice -...
Fireplace burner won't stay on
try cleaning the pilot sounds like its a short pilot and when the burner comes on it pulls the gas from the pilot light .
Feb 22, 2013 | Heating & Cooling
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
How do I turn on my superior ventless fireplace
I'm not sure about that brand, but I finally figured out how to turn the one in the house I just moved into. The only visible control if you have not accessed the fireplace controls before is the switch on the wall. The wall switch is strictly an on off switch, but it only works if the pilot light is already lit, and the pilot light will not go out by turning off the wall switch. To access the controls, first pull out the vent covers, they are simply held in place with pressure buttons on each end. Behind the lower vent are the controls for the pilot light and fire intensity, mine also contained a metal plate with the instructions printed on it. Open the glass door by opening the four latches, two on top and two on bottom, and then swinging it out on its hinge. You will find the gas spout for the pilot light hidden between the logs. Turn on the main gas line by turning the straight edge of the red handle parallel with the gas line. Turn the gas control to pilot, by pushing in and turning, and then push in all the way to start gas flowing. I like to have a match already lit next to the valve when I start the gas. After the pilot light has been on for about 60 seconds let go of the button and it will return to its normal position. Then turn the control to on and turn on the wall switch, the main burners should start lighting. Close the glass and put the vent covers back in place and your ready to enjoy the fireplace :)
Nov 27, 2010 | Heating & Cooling
Fireplace will not stay lit and pilot light is on
This sounds like the high temperature switch has failed and is telling the unit to shut down after it gets started, the pilot has to be lit for the main gas valve to turn on when the thermostat calls for heat, The main burner comes on and stays on until the thermostat is satisfied and tells it to shut off, you dont say if there is a blower in this unit, if there is a blower after the main flame comes on the unit heats up it turns on the blower if equiped. If the blower fails to turn on the unit would be shut down on overtemp as the firebox would get to hot and be in danger of causeing a fire. if no blower there still is an overtemp switch that shuts the unit down if it gets to hot or the switch is bad, it could be a bad overtemp switch or if equiped a bad blower motor or even a plugged chimney as this would also cause a overheat ing condition. Hope This Helps Don
Dec 01, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Dec 01, 2008 | Heating & Cooling
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
