Question about Kitchen Ranges
Stricker on stive tip keeos strivpcking - Kitchen Ranges
Power light keeos blinking off and on but tv will not turn on
bobnorri,
See my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting for repair help.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 27, 2011 | Televison & Video
Hi i'm stive i've motorola side kick and i livinn in syria i need to unlock it plz hlp
you can use codes to unlock your phone. its the best and simple way to unlock any phone. you can get the codes from here. its a third party provider who provides codes Mobile-Unlocker even for old model phones.
Jun 23, 2011 | Motorola Mobility SIDEKICK SLIDE Cell...
Need a new stricker you can't spin the stricker handle fast enough to make a spark
I assume this refrigerator is an absorbtion type of refrigerator, also known as a 3 way fridge ( 12volt, 240 voly and lpg gas.)
The stiker is a piezio crystal which does not wear out. The problem is that the where the spark jumps across the gap has become dirty or blocked in some way.
In general the push button should be easy to push in, if it has become harder to push in that is a sign of dirty "points"
Mar 25, 2011 | Refrigerators
Hello, I have honda accord ex, 1995 bottom driver side light kept blingking while am driving. Do you thing "Fuse" thks Jessie
I think your door might be adjust too far out and the door is not push the Door Switch in far enough when it's close. Adjust the door inward a little by loosing the stricker screws and tipping it in with a hammer. See picture below for Door Switch and Stricker.
good luck
Jan 21, 2011 | 1999 Honda Odyssey
Passenger door wont unlock/open
My wife had an old Nissan that the lock rods came off inside the door, it prevented me from opeing the passenger door. What I had to do is drill some strategic holes to gain acess to the striker on the door channel. Once I had access, I center punched and drilled the stricker bolts out so the stricker was no longer fastened to the channel. Once this was done, I was able to push the door open, remove the door panel, get in there to see what had happened and repair/replace the problem. It was a weekend project, but it was alot cheaper than taking it to a shop (who quoted me up to $1000.00). Ended up costing me only the parts (about $20.00). Good luck.
Jun 28, 2009 | 1992 Jeep Wrangler
Golf won't unlock?
Go to a VW dealer and purchase a new lock cylinder. Normally it the little tip at the end of the cylinder has broken off. If you want to keep the old keys you may have to take the parts from the new cylinder and exchange them with the old one. make sure you number the lock pins first and keep them in order, other wise it will not work. I've done it for my VW and I am not a machanic. Joe
May 06, 2009 | 2001 Volkswagen Golf
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Regards
Nov 07, 2008 | Thermador SGS36GS Gas Cooktop
Sigma EF-500 DG super
The Sigma EF-500 flashes have very small chromed contacts for the batteries. Even though they may not look corroded, they may not power up or conduct enough power to fully cycle up. Use a polishing tip in a dremel or an ink eraser tip to clean the internal wire contacts and the flat contacts on the door. I use dielectric grease on a q-tip to apply a coat to all contacts and cleaned battery terminals to minimise future issues.
Aug 27, 2008 | Sigma EF-500 DG for TTL Flash
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
