Question about Canon Office Equipment & Supplies
Having error e0024-01. All paper jamed at drum area and before delivery trey . My machine canon ir 3030. Can you help me please
  • 4 Answers
Sounds like there may be a tiny piece of paper stuck in there that is causing havoc with your paper...usually at the sides. Use a flashlight, and check carefully to see if you can find it.
Posted on Dec 11, 2016
  • Tanmoy Roy
    Tanmoy Roy Dec 13, 2016
    After starting the mch, it works for 10/15 page then paper jam with z fold starts. No piece of paper thr..
  • Tanmoy Roy
    All problems inbetween heat roller of ir 3030
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
  • 1326 Answers
SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
Posted on Apr 14, 2008
hi how do solve this problem system error E007
Posted on Apr 09, 2009
  • 149 Answers
SOURCE: Hi, i have a canon ir
This code is a fuser error code. First try and clear the error in service mode - this may help you for a long or short time depending upon the severity and cause of the problem. There may have been a jam in the fuser affecting the temperature. Press the head key (the head shape key with an asterick inside) the the number '2' and '8' at the same time, then the head key again quickly. Then press 'FUNCTION' then 'CLEAR' from the next screen - and then press 'ERROR' then 'OK'. Now, switch the machine off for 10 seconds and then back on. If your problem is not so serious then the error will be gone with perhaps only a jam remaining. If not, then you will require a new fixing film unit.
Posted on Jan 03, 2010
SOURCE: Canon ir 3100 cn error code e000020-0081
it can not print out
Posted on Feb 10, 2010
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
Canon ir 3030 printout will be black
Verify charge corona, when you start a new copy, open lateral door when paper is in the right of drum, then look if the drum is full covered with toner.
Dec 05, 2014 | Canon imageRUNNER 3030 Black and White...
Canon ir 4570 paper jaming in heater section what can i do
check your outlet delivery guide or whether your fuser film rotation
Nov 05, 2014 | Canon ImageRunner 4570 | IR4570 |
Canon ir 3030 paper loading problem in cassette
The problem could be one of several things.
1) Check your "printer preferences" setting and make sure you have selected the CORRECT SIZE OF PAPER. For example; Letter, Legal, etc.
2) Un-install and re-install the drivers.
Hope these suggestions help.
Nov 03, 2014 | Canon imageRUNNER 3030 Black and White...
A4 paper jamed in teh finsher
Go To Below official Canon Printer Page For Your problem, Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Canon Printer Support
Mar 19, 2014 | Canon Ir 3300 B/w Copier image Runner...
Has paper jamed in machine can not acess paper though any of the openings can see the paper though front bay it is jamed in between front rollers.
Not seeing this machine, if the drum can be taken out this can help.
If nothing can be taken out, be very careful when attempting to pull the paper out. Paper can scratch the surface of the drum and can pull stripper fingers out of place. Also there may be mylar fingers in place that may be bent or broken off causing further jams.
Using long pliers might work.
More description of this area needs to be given in order to pull this paper out. There might be other internal parts that need to be checked in order to keep this type of jam to occur again.
If al else fails place a service call by a copier service representative.
Oct 07, 2009 | Canon Office Equipment & Supplies
Message paper jam and open left drawer cover
Delay Jam in Delivery Assembly (Paper Leading Edge Jam at Delivery Sensor/Wound Paper Jam at Fixing
Mar 19, 2009 | Canon iR 2020i Laser Printer
old marine
old marine
