Question about Food Mixers
Cannot get the 2nd beater to attach to mixer.
SOURCE: Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Posted on Jun 05, 2008
ricardok45
  • 135 Answers
SOURCE: peeled beater and hook
Stan. If you were to keep these attachments soaking in alcohol (rubbing) between uses, I'd say yes, however this would probably make more coating flake off. This coating goes into the food you're mixing. Bacteria will remain between the metal part of the attachment and the plastic coating,where you can't scrub it off.
Replace them. Try to find all metal ones. While you're at it, throw out all cracked plates and coffee mugs too, as these cracks harbour bacteria that will survive normal dishwashing. If you are ever in a restaurant and are served food on a cracked plate refuse it and tell them not to just scrape the food onto another plate.
I spent 13 years in the restaurant business, anytime we came across a cracked plate cup or mug, into the trash it went. food and all. Dont take chances with your health. If you found this solution helpfull, please rate it Good luck. ricardok45
Posted on Jan 09, 2009
  • 4 Answers
SOURCE: Hobart N-50 Mixer beater attachment spins but has no resistance
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Posted on Jun 10, 2009
  • 1214 Answers
SOURCE: kitchenaide mixer...leaking oil underside of
KitchenAid uses a grease in the transmission, and anything that may drip from the transmission will be very low in quantity.
If you want to disassemble, clean, and re-grease to remove the liquid part that has weeped out of the existing grease, do so with a food safe grease.
Posted on Dec 21, 2009
  • 906 Answers
SOURCE: can't attach beater to kitchen aid
good day,
hope this link below will solve your problem.
kitchen
Posted on Aug 04, 2010
A mixer blade for an Oreck MKT800
Hello, Gary -
From what I have found about the Oreck MKT800 Vertical 5 Speed Hand Mixer, there is no "mixer blade" attachment for the appliance. The attachments for the mixer are:
- 2 beaters
- 2 whisks
- 2 dough hooks
You can see an image of the hand mixer with all 6 attachments here:
http://www.qvc.com/Oreck-Vertical-5-Speed-Hand-Mixer-with-Attachments.product.K6135.html
If you mean a replacement beater, whisk, or dough hook for your Oreck MKT800, so far, I have not found a source for those replacements.
Best wishes.
Mar 24, 2018 | Oreck Food Mixers
Beater is not close enough to bowl
If it is a ksm103 there should be a spring on the shaft, it should look similar to this: http://www.mendingshed.com/kacentershaft.html
When adjusting the screw you should be turning it out, which will make the beater closer to the bottom of the bowl, when properly adjusted you should be able to place a dime in the bowl, and the flat beater should just move it around barely. that would be about 1/16" in clearance.
Mar 06, 2014 | KitchenAid KSM103 Professional 5 Series...
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
I cannot remove the mixer attachment from the mixer. It will not move, or twist to the side to release.
Use a small amount of vegetable oil to lubricate the beater shaft and
the beater. Slightly tap the beater up and sideways with a rubber mallet
until you can move the beater easily along the shaft.
Jul 31, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
Need replacement beaters for Rival 12 speed stand mixer. I am unable to find any 89-attachments for this mixer as I have misplaced the beaters that came with the unit. I've looked everywhere. Are...
I cant find any information online at all about buying attachments for my new Rival 12 Speed Blender!! Does anyone know how I would find out how I could go about ordering new parts for it?
Jul 01, 2011 | Rival Food Mixers
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
How to change attachments beaters. The attachments clicked in but now I can not get it to release the beater.
The mixer does seem to resist letting go of attachments in an annoying way... this is a known issue and the only way to handle it is to 'put your back into it' I'm afraid.
Cheers, immorion
Dec 18, 2009 | Kenmore KSM100 Stand Mixer
Beater is stuck on mixer
Poor some wesson oil into attachment socketin the head and work it a little by hand ----Unplug first. Work the release button and attachment.
Oct 26, 2009 | KitchenAid 32685 Mixer
Nov 12, 2006 | Sunbeam 2485 MixMaster Series Hand Mixer
Food Mixers Logo
46 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
