Rock ola jukebox, the Mechanism breaker is tripping switch when it starts up
  • 211 Answers
SOURCE: Rock-ola 498 Carousel Spins Continuously
There is a sensor which detects the start position of the carousel and if it isnt working it goes round forever. (Although I am not very familiar with this box)
Posted on Oct 28, 2009
  • 211 Answers
SOURCE: i have a 1965 rock-ola starlet jukebox and it will
It won't reject because it needs to have the gripper arm complete the motion before the microswitches on the cam are in the right position.
It has either seized up or blown a fuse or both.
Posted on Feb 21, 2010
  • 567 Answers
SOURCE: I have a Nostalgic Bubbler Rock- Ola CD Jukebox
if its a nostalgic model email me for the manual philhemmings@hotmail.com
Posted on Sep 25, 2010
kb50100310
  • 12 Answers
SOURCE: noisy bubbler on rock-ola jukebox
Lubricating the motor MAY resolve it or the motor bearings are probably worn down. A possible solution might be to remove the motor and slightly drill or file out one of the mounting holes, permitting you to adjust the position of the motor just enough to allow for the lash in the gears to be corrected. Essentially to lube things, and the rubber drive rollers wear out also should be replaced.
Posted on Jul 28, 2015
kb50100310
  • 12 Answers
SOURCE: i have a rock ola
By disc cleaner do you mean laser cleaner? Small qtip, isopropyl alcohol 91 percent or better, very gently clean the lens eye wiping in a circular motion from center to outside. Allow to fully dry, and also a keyboard dusting spray blown onto the eye and down into the laser assy to knock away and dust particles. If the CDs are drity them remove them one at a time, use a very soft lens ckleaning cloth and glasses lens cleaner and wipe from inside out on the shiny side.
Reaplace them all and allow to fully air dry. The other things are to check and adjust the unit so that nothing drags and all discs are spinning freely while in operation.
Rock-ola 448 jukebox skipping how to repair
The stylus might be worn or of the wrong type. A simple tone arm needs a round stylus and if an elliptical type (intended for a long S-shaped tone arm) has been fitted by mistake it could skip.
If nothing is wrong there, the remaining conclusion is either the mechanism is maladjusted or the tonearm bearing has a tight spot. In that case the tone arm should be removed and the shaft examined under strong magnification and any irregularities carefully removed, eased, blended in using a very fine abrasive (12,000 - 20,000 grit) and then ensuring the shaft and bearing is thoroughly clean apply a little very light machine oil and reassemble and readjust the playing weight...
Apr 07, 2017 | The Audio Players & Recorders
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
Need to turn the volume up on my rock ola model 7000 2bx
This is a link for contact info....
http://www.rock-ola.com/Pages/contactus.aspx
Feb 27, 2015 | Wurlitzer Rock-ola Jukebox
No sound
Check to see if tone arm is in the correct position and did not get jostled out of place during the move.
Be sure needle did not get damaged.
Check to see if cartridge wires came loose during move.
Did turntable slip out of position?
Any cables come unplugged?
Any amplifier fuses blown or mechanism power supply fuses blown?
Aug 26, 2014 | Wurlitzer Rock-ola Jukebox
Rockola 470. How can I convert my 240v 50hz to 110v 60hz to supply my jukebox?
2 choices: replace power supply transformer or replace motor to get the right speed and the right sound pitch.
Sep 05, 2013 | Wurlitzer Rock-ola Jukebox
Rock-ola cd jukebox bubbles wont bubble?????
They are probably made like the old Christmas tree bubble lights. These had a solution, I think it might have been calcium chloride and they were heated at the bottom end of the tube by an incandescent lamp that ran pretty hot. The lamps in your unit might be burnt out. I remember we had to tap the tubes lightly to get them to start bubbling sometimes.
Feb 16, 2011 | Wurlitzer Rock-ola Jukebox
Look on Ebay for manuals or try at www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Sep 02, 2009 | Wurlitzer Jukebox 1015 One More Time...
Need to get wurlitzer jukebox working
Place a help request on the following jukebox forums, you will need the jukebox makers details (Rowe Ami, Wurlitzer, Rock Ola or Antique Apparatus etc) and the model number and what fault you have.
www.phonoland.com
www.jukeboxmadness.com
www.arcadecontrols.com (go to message board and then jukebox)
Regards
Alan Hood
ami-man
UK
Jun 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
Jukebox Rock-ola 464 wont turn on
Hi sullysfarm,
Here are the details of an action on Ebay for a 464 manual in the USA.
Rock-Ola 464 Jukebox Service Manual Item number: 220350796639
With regards to your jukebox not working after transportation I would check to see that you have not caught any power switches that are on the back of the jukebox (these may be in a recess) or check all the plug in connectors for a loose connection.
Regards
Alan Hood
ami-man
UK
May 31, 2009 | Vintage Jukebox External Speakers Shelf...
 Grubhead
Grubhead
