Question about Water Dispensing & Filtration
Where can I get a instruction manual for a culligan s f 10 t f 2 water softener
  • 14 Answers
SOURCE: culligan gold series 9'' water softener has a constant error code
It has been my experience that when you have made several attempts to correct the error codes as directed in the owners manual, you most likely have a defective controller.
You should contact Cuno and locate a service representative near you to see about getting the controller replaced.
sanray
Posted on Dec 28, 2008
SOURCE: Culligan Silver Water Softener - Continues to Run
Same problem, no answer... incredible how strong is the "culligan maffia"...
Posted on Aug 10, 2009
  • 175 Answers
SOURCE: No salt leaving Culligan softener during regen
It sounds like your salt in your salt compartment is stuck. Poor about a couple of gallons of hot water on top of your salt and see if that will break it up and fall down to the bottom of your salt container. Then regenerate your softener after about 3 hours have gone by. You should be back in business.
Posted on Nov 20, 2009
  • 8 Answers
SOURCE: water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
Posted on Jul 21, 2010
h2oservices
  • 306 Answers
SOURCE: I have a Culligan water softener and noticed
There is a problem with the piston/seal pack assembly pack in the valve. The seals get worn or some debris gets stuck and causes softener to run to the drain. The seal pack assembly needs to be replaced. If you are handy, you can do this. It takes about 1/2 hour for a novice.
Parts are only available from Culligan.
RJ
Posted on Jul 03, 2011
What causes culligan water softener tank to mak noise
The noise is normal during regeneration and draining.
You can manually set the regen clock to a different time.
There are Noises in My Culligan Water Softener Regeneration System Hunker
Dec 21, 2017 | Water Filters & Coolers
How to find a service manual for culligan n softener
Service manuals for Culligan units are not available on line.
Owners manuals are available for many models though.
Here is a link for Culligan units that you find useful.
http://eculligan.com/service-manuals/manuals.php
RJH2O
May 27, 2014 | Culligan 34" Whole House Water Filter...
WHERE IS OUR SOFT WATER!? A few years back we had the Culligan man out to check our water because it was not soft (at the time, we had the Culligan Mark 100 model). After testing our water, the suggested...
The most frequent causes for intermittent hard water would be the gallon settings set too low causing the softener to run out of capacity or a meter that is not measuring the gallons. I would set the "hardness" setting on your culligan softener 30% higher than actual hardness. The softening resins they use are low in crosslink and very inefficient. Also make sure there are no toilets leaking causing hard water to "bleed" through softener. Iron filters require regular maintenance to clear oxidized iron from nozzles and the valve. Generally it is better to have the iron filter regenerate at least every 3 days to keep the bed refreshed.
RJ
Mar 01, 2012 | Culligan Sediment Water Filter
Culligan medallist softener will not regenerate unless done manually, not sure how to set different locations. 1 set to present time, 2-2:00 am, 3-10, 4-10, 5-10, 6 is set to 71 degrees, 9 is set to U, 10...
How do you know it is not regenerating? When hard water occurs through system it may still be regenerating but not drawing brine or refilling the salt tank properly. First check to see if it is metering the gallons. Run water and check for the flashing icon. If it is not metering the gallons, the meter is bad, dirty (iron buildup) or the board is bad. Clean the eductor assembly on top of valve (under chrome plate) this may be plugged.
Here is a link to the manual for your medallist softener.
http://www.culligan.com/uploadedFiles/Service_and_Maintenance/Customer_Support/Owners_Guides/Water_Softener_Owner_Guides/Culligan%20Medallist%20Series%20Water%20Softeners%20fr%202007%20%28Rev%20B%29%2001020482.pdf
RJ
Aug 14, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
I have culligan house water softner. after i changed my hot water heater my softner stopped working. I dont have a manual to check. any suggestions?
Unless the softener was bypassed when the water heater went in, installing a water heater has no bearing on the softener working or not. Is it unplugged?
RJ
Aug 27, 2010 | Culligan 34" Whole House Water Filter...
Culligan 01010091 (mark 89) softener will not auto
clean the drainage filter then it will work correctly again
Mar 05, 2010 | Culligan Sediment Water Filter
I NEED A SERVICE MANUAL FOR MY CULLIGAN WATER SOFTENER. MODEL# 01014556 SERIAL# 2903H0010
Your best course of action is to contact Culligan here:
http://www.culligan-store.com/contact.asp
Nov 15, 2009 | Culligan Sediment Water Filter
Water Dispensing & Filtration Logo
1,290 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Tom Chichester
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
