Question about Daewoo Washing Machines
Daewoo washing machine door wont open - Daewoo Washing Machines
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
  • 3230 Answers
SOURCE: washing machine has f05 flashing on a hotpoint
The error F05 indicates that the pressure switch is jammed on full.
The only thing you can do your self is to check the filter is not blocked.
Remove lower rear panel of washer, locate and remove large black hose fatened to bottom of tub, watch out for water running out.
Remove and clean plastic filter inside hose.
Refit filter and hose, test for leaks.
If problem still persists, then could be faulty pressure switch or blockage in the pressure system.
Good Luck!!
Thanks
Posted on Jul 19, 2009
  • 1382 Answers
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
Posted on May 19, 2010
  • 114 Answers
SOURCE: washing machine door wont open on hotpoint
remove the front kick strip, on the LHS you will notice a yellow tag. with the power on on the machine pull down twice gently on this tab. this should unlock the door.
if you now notice the drum is full of water its more than likely your filter is blocked and this is what caused the door not to open.
Posted on Jun 25, 2011
What is meant by L E?
Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 02, 2015 | Daewoo Washing Machines
Model DWC-LD1421 WHAT DOES FAULT CODE LE MEAN ON THIS MODEL
this is the code issue for the Daewoo washers things to check The washing machine or washer dryer door has been detected as open or unlocked.
  • Close the door!
  • Check the door lock switch
  • Check the door latch
  • Check PCB
Mar 09, 2015 | Washing Machines
Daewoo washing machine model number DWC-LD1421 what dose the fault code LE mean for this model
  • Close the door!
  • Check PCB
Mar 09, 2015 | Daewoo Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
·Close the door!
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
Troubleshooting
Best bet would be to unplug the machine, leave it for 30 seconds, then try plugging it back in.
Oct 19, 2013 | Daewoo DWD M1031
DAEWOO,WASHING MACHINE.CDW-WD13WCS/RCS. Door will
This video will show you how to open your DAEWOO washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 02, 2013 | Daewoo DW500M Top Load Washer
My door won't open on my daewoo airpower washing machine. My clothes are trapped!
unplug the machine for about ten minutes and then try to open the door after you plug it in. If the plug is not easily accessable, locate the fuse in the fuse panel for it. i may add after you have interupted power to the machine, you may want to try opening the door then.
Jun 12, 2011 | Washing Machines
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Jul 19, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
