Question about Garden
My John Deere D110 snowblower won't engage. It looks like the PTO spring hits the hole in the cable bracket before the mower engages. As a result, I can not fully pull the PTO lever to engage.
When I pull on the cable manually, with the cable removed from the cable bracket, the snowblower engages. I just don't see any way to adjust this.
  • Pinney Colton
    Pinney Colton Dec 11, 2016
    Found one issue and resolved it. It looks like my D110 (newer model) shipped with an older model (longer) spring. The snowblower frame has a different location for this spring to attach to. It still won't engage, but I'm confident that this is part of the solution.
5 Suggested Answers
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
  • 6468 Answers
SOURCE: John Deere SST16 PTO won't engage mower blades
check for power at the clutch if no power check the safety switches and the switch itself
Posted on Apr 24, 2012
mikeforrest2
  • 18 Answers
SOURCE: Auger in snowblower blower does not turn
Check to see if cable is still ok and not broken. Also adjusted.
Posted on Feb 11, 2013
  • 50522 Answers
SOURCE: Replaced a broken auger control cable on my 536.881400 snow thrower, but now the auger engage lever cannot be fully pulled back.
possible that is the problem
see if you can move the end of the cable closer down the handle (control lever) to give it enough length
check how you fitted the cable and the spring may fit in a hole on the other side of where you put the cable end
Posted on Nov 30, 2016
John Deere L110 Mower wont engage
Depending on which type of PTO you have the problem could be simple to diagnose... if you have an electric PTO, you may be dealing with a bad switch... if electric, you should have good tension on the belt at all times. If it is a lever that you push/pull to engage the blades, then it would seem that the tensioner pulley is not applying the required tension on the belt... could be a broken spring or a worn/slipping belt (not enough tension)... hope that gives you somewhere to look into...
May 21, 2013 | John Deere Garden
Apr 23, 2012 | Garden
L100 John Deere mower will not engage...belt seems very loose but in good condition.
The tractor has a cable connection and a tension spring that may have broken or has came off. It's hard to say for sure without seeing the mower or guiding someone over the phone as they are looking at things. If i can help further you or someone may call me at (831)578-4034 i live in California our time zone my be different.
Oct 10, 2017 | John Deere Garden
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
Problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Oct 02, 2009 | John Deere Garden
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
John deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
