Question about Pool & Spa
Can not get my spa out of Ec mode. It is a Dream maker 260 gal spa. Oddiscey spa.
SOURCE: how do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
Posted on Nov 04, 2009
  • 14548 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: WHAT IS THE MODE BUTTON FOR?
EC stands for Economy. Change the mode until you reach ST and then it will stop flashing and function as normal.
Economy mode only allows the heater to function when the hot tub is on its filtration cycle.
Regards,
Ian.
SOURCE: I have a Dream Maker x-spa Dition 4 person spa. i
hi i am having the same problem have you managed to fix it and how any help would be much appreciated thanks joe joeathome2009@hotmail.com
Posted on Aug 06, 2010
My Dream maker Odyssey spa is stuck on economy mode. There is no way for me to see to change it to standard mode.
Try pressing 'TEMP' then 'LIGHT'. You may have to do this a couple of times.
If you don't have a 'TEMP' button, either the temperature up or down will also work.
There are three modes, ECONOMY (EC / ECO / ECON), SLEEP (SL / SLP) and STANDARD (ST / STD). For everyday use keep it on STANDARD mode.
Cheers,
Ian Kime
Ian Kime Hot Tub Sales Repairs and Servicing
May 02, 2017 | Standard Pool & Spa
If hot tub is in sl mode. How do I change it so temperature goes up
Hi, this sounds like a Balboa pack and topside control. press the temperature button along with the light button. This should put you into the filtration mode selection. Then toggle using the temperature control buttons until you find your mode ST for standard and EC for Economy or SL for sleep. You can find more information here. How to change the Filter Mode on Dream Maker Spa
Jun 05, 2015 | Pool & Spa
What does Ec mean
EC on a Hot tub shows that it is in "Economy mode" meaning the spa will only heat during a filter cycle. Not a setting to be in if you live in "cold country" (you risk having the equipment freezing up)
Nov 21, 2013 | Dream Maker Spas Pool & Spa
What is Ec code on disply mean dreammaker spa
check recirculation pump and heater element if ok temp sensor
Mar 29, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
What does ec mean on my hot tub
EC stands for Economy mode. This is a setting that tells the computer to check the temperature of the spa less frquently, as well as running fewer filter cycles. Spas should be set to EC while you are away on vacation or not planning to use it for a while
Apr 29, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
Tub is not heating to temperature and flashing a Ec message on the temperature screen.
the Ec message is reffering to the mode the tub is set for. Ec stands for Economy mode. In Economy mode the heater will only come on during the filter cycle you have programmed. It will take a while for the tub to actually heat up in this mode. Change the mode to St mode which stands for Standard mode. Your manual should explain how to do this. usually you hit the temp button then the light button to change from mode to mode. Once the St is in the read out window don't touch anything and it will except the programmmed entry automatically. In the Standard mode the tub will keep heating until the set temperature is reached. then it will come on every half hr or so to check that the temperature is maintained.
Oct 09, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
122 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
