Question about Canon PIXMA iP1600 Printer
How do i reinstall the ink cartridge rubber ribbon that came off inside my canon ip1600 printer?
  • 380 Answers
Usually, the best thing to do is go ahead and get a replacement ribbon. When a ribbon comes loose, it can sometimes snag, causing a tear, that tear can drop threads into your machinery, causing jams. If however the ribbon is alright, then you should be able to replace it without much effort. just make sure you load it into any guide slats (where applicable) and do not force anything in. Hopefully, you have the owners manual. If not, search the mfr website for a copy of that manual in PDF form or DOC form, or call their support line.
Posted on Jul 21, 2009
Canon Pixa iP1600 "an ink
Try taking it out and putting it back in again. Reseat the cartridge. Also unplug the power to the printer and plug it back in. See if it will work then. It may just need to be power reset.
Thanks for using FixYa!
Aug 08, 2011 | Canon PIXMA iP1600 Printer
I bought a refilled black ink cartridge for my
Replace color cartridge.Printer can't print without color cartridge.In your case the color cartridge is failed.
Nov 24, 2009 | Canon PIXMA iP1600 Printer
What ink cartridge to use with Pixma ip1600 ?
This printer uses a PG-40 Black and CL-41 Color cartridges.
For reference here is the main support page:
Canon ip1600 Support
Click on Supplies & Accessories.
Oct 22, 2009 | Canon PIXMA iP1600 Printer
Help!Have Canon printer.Changed cartridge, but can't print!
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Oct 16, 2009 | Canon PIXMA iP1600 Printer
We had just refilled the ink cartridge for canon ip1980
please reset manual first by pushing power button before plug in AC cord, then push resume button twice and release both, if still happen please reinstall driver
Mar 03, 2009 | Canon PIXMA iP1600 Printer
Canon ip1600
Dear hoppygink,
Canon pixma ip1200 series (ip1200,1600,2200) identify the first new cartridge installed in the printer and detects ink level properly unless you put another used cartridge or you its own cartridge to another printer. Once you do this, ink level of the cartridge become unknown. So, never exchange its own cartridge with another ip1600 printer. This will be back to normal condition when you replace with new fresh one catridge that never used before. This weakness has been improved by canon in pixma ip1300 series (ip1300 & 1700) anyway.
To prevent this problem occurs, you need to back up EEPROM data of the printer by using EEPROM restore tools before perform cartridge exchange. I will discuss this in Canon Inkjet Forum in the next coming chance. Please send me your email to: ijxpert@gmail.com so I can notice you immediately after posting the topic.
Regards,
Dec 12, 2008 | Canon PIXMA iP1600 Printer
While replacing the ink cartridges a clear ribbon came off. What is this for . My printer is a canon pixma ip1600
The printer needs to be repaired. That clear ribbon is an encoding strip and tells the controller what position the print head is in with respect to its travel back and forth across the platen. The printer will not work without that strip in place.
Dec 09, 2008 | Canon PIXMA iP1600 Printer
The black cartridge cannot be recognized
dear ****
try this methode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
and try to print
thank's
cropp
Mar 15, 2008 | Canon PIXMA iP1600 Printer
Printer wont recognize new or old cartridge
Use a Q-Tip and some clean water to clean the contacts behind the cartridge in the printer and on the cartridge itself. Then use a pencil with a clean eraser to polish the contacts. Be careful not to touch the part where the ink comes out of the cartridge.
Also, are you using Canon ink or third party?
Jan 09, 2008 | Canon PIXMA iP1600 Printer
Canon PIXM iP1600 ink replacement
Each time the cartridge is removed from the printer an "empty cartridge" message appears and a blinking amber light will come on, on the printer. Holding the paper feed button down for 3-5 sec. will allow you to override the counter.
Oct 26, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
104 people viewed this question
old marine
old marine
