Question about Crafts & Hobbies
Dickinsonville express train runs but extremely slow & won't hardly pull
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
Perego Choo Choo will make noise, but won't move
the sounds are run off of a different battery source, check the battery under the seat and make sure that its connected
Apr 06, 2012 | Peg Perego Choo Choo Express Train Set
1988 Playskool Expres Train engine won't run. Light comes on but wheels won't turn. How can I repair it?
i recently restored a playskool express train that my son had, now for my grandson.
The on-off push switch is the yellow button in the smookestack also controlled by the yellow tab on the bottom (the on-off track can stop the train with the tab). If the light is on then perhaps the forward reverse switch (the yellow bar behind the cab needs to be pushed forward or backwards. In the middle might be off. I had to replace the motor, its a common sized DC motor 6V at 15000 RPM w/ 2mm shaft, for toys..
The bigger problem I had was that the battery cover was very finicky in how tight you closed it, and the rubber traction bands for the driving wheels were rotten. I replaced them with 1-5/16" ID x 1/8" O-rings. Still slips a little.
Dec 10, 2011 | Playskool Toys
There is electricity coming from the tender of the Polar Express O gauge but the engine does not run. Is there somewhere to send it for repair?
Check with the store you purchased it from. If they don't repair trains they should be able to direct to one that does. You're not the first person to need repairs so they will know.
Jan 25, 2011 | Lionel The Polar Express Train Set
We just got the Hogwarts express and it will not complete 1 loop without derailing or the cars becoming uncoupled.
Well you should probably check the radius of your curves. The Hogwarts Express has a minimum curve of O36 and on a tighter radius curve it will derail. I have found that the Hogwarts train runs better on fasttrack than standard O. You should also make sure the track is flat because if it isn't completely flat it derails. The train isn't designed well so it derails but if you run it slow you shouldn't have a lot of problems.
Dec 27, 2010 | Lionel 7-11020 Harry Potter Hogwarts...
Runs very slow... hard disk constantly running
You need to defrag your drive, make sure no unnecessary resources are running in the background and delete your temp folder as this fills with allsorts of rubbish you do not need and slows the operating system significantly.
Jan 05, 2010 | Toshiba Satellite A45-S150 Notebook
I bought the set last year of holiday lionel trains g replaced batteries, have light on remote and noise from engine but no movement? any ideas
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
Dec 23, 2009 | Lionel Trains Holiday Express G Gauge...
Crafts & Hobbies Logo
123 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
