Question about Bernina Sewing Machines
I have a 440QE Bernina and when I begin stitching, the thread on the top is discolored yellow for about 15 inches. This did not use to be the case. I faithfully keep my machine oiled.
  • Bernina Master
  • 11,140 Answers
How much oil are you applying to the machine? Should only be one drop on the shuttle/hook area. If oil is discoloring the thread, then it is picking it up somewhere that it shouldn't. You might try wiping out any excess oil and keeping it clean.
Posted on Dec 11, 2016
Testimonial: "I only oil where it tells me by the two little holes by the bobbin case. Where else could this be coming from?"
Screen goes blank and then stops sewing. I have a Bernina Aura 440QE 8years old.
You should probably take it to Bernina for repair. Sounds like possibly a board or component.
Nov 08, 2015 | Bernina Sewing Machines
Bernina 440QE, when I'm using the embroidery module, the machine stitches for 36 stitches then says there is a thread break when there is not, how do I resolve this issue.
there could be a sensor problem, if the machine continues to have the problem then having the machine checked would be a good idea
Feb 19, 2015 | Bernina Sewing Machines
I have an older Bernina 830. I am having what seem to be tention broblems with the stiches not forming and lots of thread being produced. The adjoining problem is that there is a rattling when I attem
What you're describing is commonly called a 'bird's nest' for fairly obvious reasons. There are, unfortunately, a number of things that can cause it.
Troubleshooting steps:
1. Clean it! I've seen machines that haven't been properly cleaned for years. If there is lint, dust or dirt in the bobbin area especially, the looper won't work correctly and the stitch won't form. Be sure to take out the bobbin when you do this.
2. Oil it. Follow your manufacturer's instructions for this. If you don't have a book, contact Bernina and get one.
3. Change the needle and check the tensioning disks to be sure that no lint, old thread, etc. has got caught in it.
4. Adjust the tension. This can be tricky, so take it in small increments. Here, again, a manufacturer's book is a godsend.
5. If none of this avails, or it only partially fixes the problem, take it to a reputable service center (most fabric, quilting, etc. stores have or know someone) and have them adjust the timing. Most machines need this done every 1-5 years depending upon the usage.
Good luck with it. I wish I had an older Bernina, they're good machines.
Feb 14, 2015 | Bernina Sewing Machines
My Bernina 200 bobbin thread snagged and now the bobbin thread will not catch the top thread when I sew, thus, there are no stitches made in the fabric.
1. CHANGE NEEDLE.
2. ADJUST BOBBIN TENSION. MAKE SURE YOU ARE USING THE RIGHT BOBBIN FOR THE MACHINE. THE WRONG ONE WILL NOT ROTATE FREELY. HANG FROM FINGER AND BOB. SHOULD EXTEND ONE INCH WHEN ADJUSTED RIGHT.
3. ADJUST TOP TENSION. (START AT 3)4. EXTEND TWO INCHES OF THREAD FROM BOBBIN. HOLD TOP THREAD TO THE FRONT AND A LITTLE TO THE RIGHT.
5. TURN HAND WHEEL TOWARDS YOU. THE BOTTOM THREAD SHOULD COME UP FROM UNDER THE PLATE.
6. IF THE THREAD DOESN'T FEED FROM THE BOBBIN TO THE TOP OF THE PLATE THE TIMING IS OFF AND WILL NEED TO BE ADJUSTED.
Jan 02, 2015 | Bernina Sewing Machines
The lower tension on my bernina 1005 stitches ok for a couple of inches then goes loose for a bit and then back to normal - normal checks done including a new needle?
Is your bobbin case a genuine Bernina bobbin case? If not, replacing the bobbin case will solve the problem. It is a common problem to find a Oriental copy of a bobbin case in a Bernina machine for a number of reasons, such as where the casing was swapped by accident or intentionally. Most often, repair technicians don't know the difference and would rather pay $7.00 for a Chinese casing rather than $56.00 for an OEM casing. Whatever the case may be, if the machine tension nests on the bottom side, stitches erratically, or breaks thread, changing the casing can solve the problem.
The bobbin cases may have similarities but there are subtle physical differences that prevents thread escapement over the bobbin case.
Much more information would be needed in order to discover your problem, however.
Other problems can occur by incorrect starting of the machine such as beginning sewing by holding the top thread rather than turning the machine hand-wheel in the direction so that the take-up lever is at the highest position. Machines like the 1005 do not have an automatic "Needle Stop' function.
There can also be similar problems if an industrial cone spool is used where thread is being pulled off of the spool's side rather than from the top center of the spool.
If the bobbin case is an OEM casing it is possible that the "loop lift (needle and sewing hook) timing" has been knocked out such as having had a collision of the needle with a button, zipper, straight pin, etc. Bernina 1005's and all of the newer machines are not constructed in such a way that would prevent this from occurring. As mentioned, more information would be needed here.
SewTechnical Home
Jul 04, 2014 | Bernina Sewing Machines
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
Bernina 180 thread breaking and tension problems
First make sure that you are using a new needle in the proper size. A needle with burrs on it will cause the bird's nest problem. Also, is the thread you are using old? My repair guy told me to keep my filled bobbins in the freezer to maintain their humidity, and that has made a world of difference in my stitching. Finally, how long has it been since you had the machine cleaned and serviced, and was it by an authorized Bernina repair shop? Bernina machines have special screws that only Bernina authorized repair people have - I discovered that when I took my machine in to someone who was not authorized only to have the timing go off in a matter of weeks. The authorized repair guy found clumps of thread that had been air blasted into the inner works of the machine and those clumps were getting caught up in the new stitching and causing the same problems you described. Good luck!
Feb 06, 2009 | Bernina Artista 180
Sewing Machines Logo
44 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
