How do I restore the sound?
Volume is at max but no sound.
HP Elitebook 6930p, Windows 7 64 Premium Home. After a morning of making Microsoft Updates, the sound volume from my laptop speakers became hardly audible.
Wild guess the updates may have affected old sound card driver. There may be an updated driver for the sound card. I believe Glary utilities free version is providing updated driver information. You may want to try that.
Mar 04, 2015 | HP EliteBook 6930p Notebook PC
Max volume to low
Check the settings of the monitor for audio volume. Also check the individual volume control setting for the applications and system sounds. Or call ViewSonic technical support for assistance.
Jun 15, 2014 | ViewSonic Computers & Internet
My samsung galaxywant give alerts or ring
Setting/sound/volume/ 4 sliders, set these to max.
Ensure your Sim card is inserted correctly and you have network coverage.
Enable WiFi. Enable mobile data(network charges will apply).
Download Samsung push service from the app store ...should already be installed.
If all fails. Backup your phone on a computer or cloud service and restore factory settings (last resort) ensure all your contacts are saved to your Sim card.
Contacts/settings/import/export to Sim/all.
Settings/backup / Restore factory settings.
May 30, 2014 | Cell Phones
I have a toshiba 26LV610U that has low volume. Most of the time I keep the volume at 40 - 50, but some DVD's are impossible to hear at max. Is there an internal volume adjustment that will amp up the...
Tries tv menu Sound Setting adjustment.Tries all the setting to the max like treble,bass,balance and surround sound is on.This should help make the audio louder.
Jun 10, 2011 | Toshiba MD19N1 19 in. TV/DVD Combo
Can't get the volume to work.
right click on sound icon ...mute off????....all volume controlls 80%....master volume max
Go to speakers see that wires are connected correctly ... line in...line out... Microphone.in..
see if manual control is max on speakers
Nov 25, 2010 | Computers & Internet
My receiver on my Iphone is low how can i increase the volume mind you the volume is at max
If the receiver is that low (and the volume level is at max) there may be a hardware issue related to the internal receiver. The piece is replaceable, but must be serviced by Apple or have your iPhone replaced by AT&T (if under warranty).
In some models of iPhones, this was a known issue that would occur through normal wear & tear. An easy way to tell if it is a hardware issue is to pair your iPhone with a bluetooth headset. While keeping the volume level at max, is it louder or the same as the iPhone's built-in receiver?
If it is louder, than chances are pretty good that the internet receiver needs replacing. If not, then you may have a software issue affecting the sound levels. Try rebooting your iPhone as this tends to "fix" a great many issues affecting iPhones. If that doesn't solve it, perform a sync to backup data, next update or restore your iPhone and then perform the test again.
Mar 16, 2010 | Apple iPhone 3G
Sound problem
Check taskbar volume control and make sure its max. If you have volume buttons make sure they are maxed. Some laptops are a key combo to increase/decrease volume. Make sure whatever program you are running that the volume slider is all the way up. Go into your control panel and double check your volume settings. Go into your device manager and make sure there are no exclamation points in yellow next to any audio devices or codecs.
Mar 09, 2010 | Toshiba Satellite Pro A210-EZ2203X...
My mix max volume is all the way to its max but it still sounds very low
I had the same problem with standard over the head earphones, however, when I used it with earbuds, the volume increased tremendously and we now have no problems with the volume sounding too low. My daughter has a hard time with regular earbuds, so I purchased some "clip" style earbuds.
Jan 07, 2010 | Disney Mix Max Digital Media Player
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
