SOURCE: please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the
set, and get the regular red blinky lights, hold down the Device and
Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
SOURCE: sanyo dp50747 Plasma HD TV
I just had mine fixed and the guy said " ITS THE POWER SUPPLY" tv nows works fine after repairs but my ps3 won't work on this tv any clue or is it just cheap engineering and I just get what I pay for!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: my flat screen sanyo tv screen wont turn on. the
Try disconnecting the connector KBL on the main board as shown in my picture #DSCF0585 to see if the backlights will come on, if it does, the main board is bad.
Also check the voltages on the output connectors of the power supply.
http://s807.photobucket.com/albums/yy352/budm/SANYO%20TV%20DP26649/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
