Question about Miscellaneous
I oreded 3 boxes of chocolate and they said they would be here sat but I did not got them
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
The positive things for chocolate
Benefits of Eating Chocolates-
1. Provides relief from stress
2. Helps to increase efficiency of brain
3. Helps to prevent cancer
4. Gives relief from a cough and cold
5. Helps to maintain healthy heart and optimal blood pressure
6. Aids in proper functioning of nervous system
May 21, 2014 | Cooking
I live in a hot country, do I need to keep chocolate in the fridge?
Ideally you should keep your chocolate in a cool, dark and dry place so that the chocolate doesn't absorb any external odors. But if chocolate is exposed to hot temperatures it can cause the chocolate to "bloom" which is what causes the gray color you sometimes see on chocolates that have sat around for too long. If you live in a really hot place, you should keep your chocolate in the fridge but in an air-tight container.
Feb 25, 2013 | Cooking
My mum loves hot chocolate and I thought a gift set of some kind would be great for her birthday. Any ideas?
Here are some sites that specialize in chocolates and also sell drinking chocolate. Their gift boxes are a really nice way of combining your mum's love of hot chocolate with something a bit special.
http://www.divinechocolate.com/shop/chocolate-gift-sets
http://www.vosgeschocolate.com/product/couture_cocoas_giftbox/drinking_chocolates
Feb 25, 2013 | Wine & Spirits
No remote. How do I reset the menu or channel programming? Using sat box, but can't get the TV to channel 3.
You best bet really is to locate an original and not a universal remote for the set
Apr 08, 2012 | Televison & Video
Hi I am trying to program my Hitachi Plasma with a rogers provided universal remote. 5 button. I can program the TV but i cannot program the digital cable box. What am I doing wrong? Please help...
the sat and cable boxes are like DIY items , just use a known set top box like dreambox e.t.c. ,i have a problem with my Logitech remote and pace HD sat receiver,evrey 2 -3 the sat receiver changes remote codes :) and its very annoing, but ill switch to a LED tv with integrated sat so for know acceptable i have a tip for you regarding receiver -change mylar and ceramic caps to film ones
Mar 23, 2011 | Yamaha RX-V750 Receiver
I just purchased a chocolate fondue fountain without a manual. where do I put the chocolate? How long does it take to heat?
Put the chocolate in the bottom. Read the box to make sure you don't have to use a specific kind of chocolate. Depending on how much chocolate you are heating and whether it is already liquid when cold would determine heating time but usually 15-20 minutes would be the minimum time.
Aug 19, 2010 | Helman Group Helman Black Chocolate Fondue...
Hi! I lost the instructions and wanted the recipe for chocolate fondue for about 60 people. Thanks so much for your help.
With out without a fountain this link is pretty good. FYI One Pound of chocolate Fondue will feed 10 people grazing. So for 60 people you will need at least 6 lbs of dark chocolate.
Link:
http://www.ellenskitchen.com/bigpots/plan/chocfont.html
From the linked page....
MICROWAVING THE CHOCOLATE Pre-melting your chocolate or sauce recipe in a microwaveable zip-lock bag speeds the maintenance of the fountain. The chocolate MUST be placed in the microwave in the bag with the proper amount of oil added (a good estimate is 1/2 cup of vegetable oil per 5 pounds of high quality chocolate) on medium power for 3 minutes. Then the chocolate should be stirred by smashing the bag around- hold in oven gloves, it will be hot- or with a rubber scraper and put back in the microwave. Microwave again on low power for an additional one to three minutes. Carefully pour the melted chocolate into the preheated fountain, preheated 3-5 minutes at 100 °.
Any blackening of the chocolate hints that it is burnt, if this occurs, discard it. It will spoil the entire batch.
Check out the fruits recommendations of the same link too!
Jun 23, 2010 | Sephra Elite Chocolate Fondue Fountain
What type of chocolate should I buy ?
go with the secord brown thats the best!!!
Sep 04, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Missing instructions for chocolate fountain
GO IN A STORE THAT SELLS THEM AND READ THE DIRRECTIONS ON A NEW ONE , COPY IT DOWN ON PAPER AND PUT THE DIRRECTIONS BACK IN THE BOX OF THE NEW ONE. MAKE SURE YOU DON'T RIP THE BOX WHEN YOU OPEN IT.
Jun 05, 2008 | Kitchen Ranges
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
