Question about Panasonic Kitchen Appliances - Others
Hi i want to know how much is the ,ARE50A805 Panasonic Pan
Need to know exact order of adding ingrdx to Panasonic BT65P bread machine pan
All dry ingredients first, then liquids, close lid and add yeast to dispenser. Here is a link to manual. see pages 14, 15.
https://www.manualslib.com/download/1251626/Panasonic-Sd-Bt65p.html
Dec 28, 2017 | Panasonic Kitchen Appliances - Others
Need to download owners manual?
Hi James, The link below is a Free 48 page user manual for a panasonic viera tc-32lx 32" 720p LCD HDTV.................CHEERS..
https://panasonic.ca/viewing/ALL/TC-32LX34/OI/TQB4GC9046-eng/TQB4GC9046-eng.pdf
Apr 30, 2016 | panasonic viera tc-32lx34 32" 720p lcd tv...
Is there any place to buy replacement insert pan for Panasonic SR-NA18 rice cooker?
I am looking for the same thing. I was able to dig in Panasonic's parts site, and come up with part number ARE50A805 for the 10-cup pan for this rice cooker.
Unfortunately, so far I have not been able to find anywhere that actually has one; several listings, many of which go back to partstore.com, but then partstore or another site I've seen referred to are not accessible.
Sep 07, 2010 | Panasonic SR-NA18 10-Cup Rice Cooker
The paddle on my panasonic breadmaker has stopped turning. Without the pan the mechanism revolves but once the pan is in place the paddle does not move.
If you take the pan out of the machine and can't turn the paddle freely by hand, then the sealed bearing is frozen. You can try putting warm water in the pan and soaking it. After a few tries if it does not free up then the sealed bearing is broken and bread pan needs to be replaced. Good Luck..Hank
Feb 06, 2010 | Panasonic SD-YD205 Bread Maker
Panasonic SD-YD205 Bread Maker: Paddle gets stuck then continues.
Take the bread pan out of the machine and run a kneading cycle. If it is noisy with the pan out then you can take the belt off and try a kneading cycle again. If it's quiet, the yep it's the belt. If still noisy its a gear or the motor itself. If everything is quiet with the pan out then it's the pan itself. There is a sealed bearing in the pan that allows the paddle to spin. The seal on the bearing leaks oil and the bearing either freezes or does not let the paddle spin freely. There is no replacement for the sealed bearing ..and a new pan is needed. Good Luck Hank
Dec 10, 2009 | Panasonic SD-YD205 Bread Maker
Panasonic SD-250 not mixing. Pan was submerged in water.
Hello LT,
There is a sealed bearing and shaft on the bottom of the bread pan that the paddle sits on. Submerging the whole pan in water may have caused water to seep into the bearing on the bottom of the pan, or the whole pan might be worn. Slight resistant in 2 places on 360 degree is not bad. Let everything dry out and we will try a few things. First, put the paddle in the empty pan and place it in the machine. Start a kneading cycle and look trough the lid to see if the paddle is spinning freely and with smooth motion 360 degrees. Watch it until you are sure it will run freely for the entire cycle. If it does not run freely, stop the machine and take the pan out. Now start the kneading cycle again with the pan out and look at the motor shaft at the bottom of the machine to see it it is running freely. If it is running freely, then the problem is with the pan, and the pan needs replacement. If the motor shaft is not turning freely, then the belt is slipping in the machine and needs to be replaced. If everything runs smoothly check the kneading time to make sure your mix has enough time to knead correctly. Hank
Nov 14, 2009 | Panasonic Kitchen Appliances - Others
Hi I have a model no: SD-200 and the bread pan is very scratched and the bread is very hard to get out, can I purchase a new one? thanks Vicki
Here is a supplier of spare for the Panasonic SD200 Breadmaker.
The parts are expensive!
www.espares.co.uk
Stock Number: ES145594
£59.99
Regards
Alan Hood
ami-man
UK
Sep 09, 2009 | Panasonic Kitchen Appliances - Others
National brand rice cooker
Hi. Checked on Australian Panasonic spares website for part no ASR111-494F and apparently it's no longer available. Panasonic spares would all come from the same source, so it's a good chance it's unavailable worldwide. Sorry.
Mar 19, 2009 | Kitchen Appliances - Others
The pan is stuck in my Sunbeam bread machine
I just had the same problem. What the manual either does not tell you or hides quite well is that you have to TWIST the pan before lifting it out. I don't know why this was listed under the Panasonic bread machine when it clearly refers to the Sunbeam bread machine.
Feb 05, 2009 | Panasonic SD-YD250 Bread Maker
Kitchen Appliances - Others Logo
63 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
