Question about Miscellaneous
Hi I ordered 3 boxes of chocolate and I was told I would get them on SAT and they did come what happened
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
How do I set the TV up for satellite TV
The TV will likely require a Satellite TV converter box. The output of the box should be mated to the best matching input of your TV.
That order would be: 1) HDMI, 2) Component (RGB) + Stereo Audio, 3) S-Video 4) Stereo Audio, 5) Composite (Yellow) and Stereo Audio 6) RF (Coaxial).
When selecting 6) RF (Coaxial), you would normally select an output channel on the Sat Box (Ch3 or Ch4) and set the TV tuner to the same channel. A standard coax cable would be installed between the Sat box connected and the TV Ant connector.
All other TV inputs would match the one you used (HDMI, Componet, etc.
Mar 16, 2016 | Televison & Video
I live in a hot country, do I need to keep chocolate in the fridge?
Ideally you should keep your chocolate in a cool, dark and dry place so that the chocolate doesn't absorb any external odors. But if chocolate is exposed to hot temperatures it can cause the chocolate to "bloom" which is what causes the gray color you sometimes see on chocolates that have sat around for too long. If you live in a really hot place, you should keep your chocolate in the fridge but in an air-tight container.
Feb 25, 2013 | Cooking
Can you order chocolate covered fruit online or is that something you have to make yourself?
You can definitely order chocolate covered fruit online. My favorites are strawberries. They come in boxes or on platters and although you can make them yourself at home, they are even nicer when they are delivered to your door.
Check out this link to the Dipped Fruit site -
Hi I am trying to program my Hitachi Plasma with a rogers provided universal remote. 5 button. I can program the TV but i cannot program the digital cable box. What am I doing wrong? Please help...
the sat and cable boxes are like DIY items , just use a known set top box like dreambox e.t.c. ,i have a problem with my Logitech remote and pace HD sat receiver,evrey 2 -3 the sat receiver changes remote codes :) and its very annoing, but ill switch to a LED tv with integrated sat so for know acceptable i have a tip for you regarding receiver -change mylar and ceramic caps to film ones
Mar 23, 2011 | Yamaha RX-V750 Receiver
Not necessarily a problem, but... I have a pair of size 7 women's Sorel Snowlion navy boots. I don't remember where I ordered them from. Was told to order a size smaller than shoe......well, they are...
your problem can be solved out it try ordering 81/2 women/'s that would exactly what you want
thank you if you are staisifed with my answer please vote 3 thump up for me
Nov 29, 2010 | Sorel Snowlion Shoes
I have a sharp carosel and tried to microwave bitter chocolate in it like many times before... it arched... I contacted Baker Chocolate and they said to put it in a bowl on a plate - did this many times;...
NEVER put anything metal in the microwave. If your chocolate was in aluminum foil no wonder it arced. That is very hard on the microwave.
If the metal were in PERFECT contact, then it would not arc, however that condition is unlikely. Just touching doesn't count... If it was welded and could not touch other metal or the walls, you MIIGHT get away with it.
When Baker told you to put it in a bowl, that MEANS the bare chocolate.
ALSO NEVER put bowls that have metalic trim as the trim will arc to itself.
Dec 27, 2009 | Sharp Microwave Ovens
LG chocolate screen
take it to your service provider's store. they will replace it for you
Aug 11, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Jul 01, 2007 | RCA RCR450 Remote Control
Miscellaneous Logo
15 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
