UHE-CM65 Homedics Cool Mist Humidifier no longer mists what might be the issue, have not had a year
Think it was tipped over, so can it be fixed?
fwadley
  • 482 Answers
SOURCE: mold in vicks cool mist vaporizer
if you can take it out side and plug it in, put some bleach in it and let it run for a few minutes. then wash it out and run the rest of it out.
Posted on Dec 16, 2007
  • 7 Answers
SOURCE: Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Posted on Feb 12, 2008
  • 7 Answers
SOURCE: Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See http://www.fixya.com/support/t253969-cleaning_instructions
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
c7121
  • 160 Answers
SOURCE: I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Posted on Dec 13, 2009
I have the HD15 how do you clean it latly everything is covered in a chalky mist in the room?
Hello FREIDA GRAYDEN,
If you are not TOTALLY SATISFIED... and that has
the SHARPER IMAGE price tag...
(in y opinion... I would return it to SHARPER IMAGE
and us the REFUND to buy 3 to 5 equivalent units ...
(like HoMedics) for a whole lot LESS...!!
(in my opinion)).
More units... less WATER spritzing around =
HAPPY FREIDA (I think).
I sincerely believe... the "chalky" you speak of is
merely a product of the CALCIUM level in your
water... and a mist type of humidifier. Nothing
wrong with your humidifier (follow owner manual
cleaning instructions) BUT what you see is normal
Sharper Image EV HD15 Instruction Manual Page 3
THE VISIBLE "mist" Your humidifier puts out are
solid water drops... It WILL mark whatever it
lands on...
I think there ARE things you could try...
Obviously turning down the humidifier to
merely moist... rather than SPRITZING water
on everything (solid/visible).
Spread the load between multiple machines
(as described above)
Perhaps...filtered water might help
Dietary CALCIUM is a very good thing... and humidity
is much more warm and comfortable... but the combination
is going to give you those SAME results...
But at those SHARPER IMAGE prices I would
expect YOU to be TOTALLY SATISFIED.
Carnac the Magnificent
https://www.amazon.com/HoMedics-Cool-Mist-Ultrasonic-Humidifier/dp/B00EW1QJPS/ref=pd_sbs_201_2?_encoding=UTF8&pd_rd_i=B00EW1QJPS&pd_rd_r=S79PF7TS0FVV4D24Y2GP&pd_rd_w=jrPo2&pd_rd_wg=POkzf&psc=1&refRID=S79PF7TS0FVV4D24Y2GP
Jan 11, 2018 | Humidifiers
How to clean homed is humidifier
Hello, Mary -
This is the link to the PDF document with the Instruction Manual for the Homedics Humidifier model UHE-CM45:
https://www.homedics.com/media/documents/homedics/instructionbooks/UHE-CM45_IB.pdf
Cleaning instructions start on Page 9 of the instructions.
You can download and save the instructions as well as print them, if you wish.
Best wishes.
Jan 08, 2018 | Humidifiers
Need directions for homedic ultasonic humidifier
http://www.homedics.com/cool-mist-ultrasonic-humidifier-3574.html
Dec 08, 2017 | Humidifiers
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
How do you post a tip?
Hi Jon,
The categories should appear in a dropdown as you begin typing. There are many categories, which is why they are not all listed at once. Start typing and you should see a dropdown appear.
Also note that when posting a tip it may be a short time before the tip will show since tips must be reviewed.
If you continue to have problems, please leave me a comment or feel free to contact the Fixya Support Team for more help with troubleshooting.
http://www.fixya.com/contact
Hope that helps!
Nov 21, 2015 | FixYa Computers & Internet
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
My homedic s humidifier is leaking.I turn it on in the evening and next morning I see it in a puddle of water.Happens every time.
Chances are it is just condensation not leakage if it's only wet when its running. Nothing you can do except put a towel under it.
Dec 01, 2014 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Ultrasonic humidifier's fan isn't running, the light indicated red instead of blue, and there is no mist coming out. How to fix it please since we cannot afford for another one right now.
I had the same problem. Looked up the manual online. Red light indicates water level is low I had just refilled the tank so that was not the problem but manual said to make sure water tank was firmly, securely seated on base. I unplugged the unit, unscrewed the plug on the tank and screwed it back on and then made sure the tank was securely seated on the base, plugged it in and it started working. If the tank is full you may just have to make sure the tank is fitting properly in the base.
Feb 05, 2014 | Homedics Uhe-oc1 Cool Mist Ultrasonic...
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
