Question about Vacuums
Lux legacy question mark lite up and vacuum wont't start?
4 Suggested Answers
  • 694 Answers
SOURCE: lux legacy canister vacuum - the top light on the
The "plug" light simply tells you the machine is plugged in and receiving power.
I'm not sure what you mean by "no power to the bottom of the roller". If the power nozzle motor isn't working, make sure nothing is wrapped around the brush, remove if there is, and press the reset switch.
If the power nozzle motor is running, but the brush isn't turning, then the belt must have broken, and needs to be replaced.
Considering your machine may still be under warranty, I suggest taking it to a local Aerus dealer and having it replaced.
You can find the store nearest you using the below site:
http://www.aerushome.com/shop/
Posted on Sep 05, 2010
  • 694 Answers
SOURCE: Lux legacy vacuum runs fine
You don't mention whether it was the canister or upright model, but if it sounds differnet than what it usually does, then there is a potential problem. It could be anything from a full/clogged bag to a dirty filter to a clogged hose. You can check the hose by tyring to drop a coin through it.
If you didn't get it serviced at an authorized Aerus Electrolux shop, there could very well be other problems that were caused by an untrained service tech.
If it was recently serviced, and none of the above suggestions solve the problem, take it back to the shop that serviced it.
Also, keep in mind that these vacuums carry a 10 year warranty, but if serviced by a non-Aerus shop, the warranty is voided.
Posted on Apr 01, 2011
  • 51174 Answers
SOURCE: Will not stay running
is it getting hot .perhaps filters need good cleaning
Posted on Feb 07, 2015
Feb 07, 2015 | Vacuums
Lux Legacy vacuum cuts off every few minutes. It comes back on almost immediately. It has new bag and after filter and is not clogged.
Check filter door cover is on tight, latch is locked. This happened to me with another brand.
Feb 07, 2015 | Filter Vacuums
What is the difference between the electrolux lux 7000 and the electrolux lux legacy
different motor,the legacy does not have a filter,but the same bag...one is made of a light metal [legacy] the other a polycarbonate plastic. Chris
Jun 24, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux 7000 vacuum cleaner power cord light is on and it wont start
Best case scenerio....check and replace the bag...try it. If no bag, it won't start. If that's not it, could be the on/off button or rocker needs replaced and worse case scenerio, the motor is OUT!... I can help! amerivac4u@yahoo.com
Jun 06, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
I need a manual for an epic 6500,lux legacy, and a guardian
Owner's manuals are available on the Aerus site. Those three are under the "Older Model" tab. Simply download.
http://www.aerusvacuums.com/support/manuals/
Service manuals are only availabe to franchise owners and service technicians in authorized Aerus stores. They're available to those personnel through software Aerus provides to them.
Apr 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Vacuum cleaner Lux model motor fails to start
This vacuum has a 10 year warranty on the motor, and 5 years on everything else. Look in the yellow pages under vacuums, for the AERUS dealer, that is the new name for the traditional Electrolux company.....
Mar 23, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux legacy
Actually the problem is inside of the canister itself. You need to change a part called the control valve. Occaisonally when fine particles get inside of the valve it damages the inside of the valve, sending a false reading to the main motor, causing it to shut off. This is a relatively quick and easy repair and should be recieved on a same day basis.
Oct 20, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux 7000 Power Nozzle bulb replacement
There should be some screws that you remove from the bottom. Then pry up from the back and the top should come off.
May 11, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux Legacy shuting off by itself
i would say it is over heating but some times you cant tell because electrolux have a sensor so when the get hot the turn off till they gool down soo if you really like the vacuum get it look at by a vacuum repair man.
hope this helps
May 10, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
