Question about Dual Electronics XDVD700 Car DVD Player
My screen on my dual xdvd600 will not light up and will not close but the stereo still works u just can't see the screen and it will not close out open
Changed car battery and the dual car stereo won't work now. reset the stereo and the security light is flashing and the stereo still won't work?
Your solution depends on the brand and model number of your stereo system I take it your stereo system is Ruth is included in a anti-theft device this is highly technical and manufacture specific you need to follow the instructions for installing the system initially somehow your system lost sanity. You need to unplug the fuse that goes to your stereo turn your stereo switch on and let it sit for a day then return with the users manual and go through the installation sequence that has to do with connecting power and setting default settings other than that you have to contact the manufacturer
Nov 25, 2014 | Dual Xdma6540 Car Stereo Receiver
E message during play
Transport needs work it needs to go to the Technician.
Apr 01, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Dual CD770 (Same as XDMR7700) face stuck open (down)
Change the Flex cable that connects from main chassis to the front face plate. This is a common problem with Dual drop down face plates, since the flexible wires break and lose connection.
Mar 06, 2013 | Dual XDMR-7700 CD Player
Dual XDMA7650 all wire hooked up, unit will turn blue but the display wont light up. Tried holding the power button nothing. Please help me I am so frustrated!!
i have this same issue it lights up blue and plays music ...the inner screen lights up and what not but the outer screen will not light up at all helpppppppp
Mar 04, 2013 | Dual XDMA7650 In-Dash CD/MP3/WMA Car...
Need manual for SJ816
Dual Sim Dual Standby
--Means you can insert 2 SIM cards into this cell phone, and these 2 SIM cards are ready to make a telephone call or answer a call, no need to shut down the phone to switch SIM card, just like get two mobile phone! (no doubt It can work with only 1 SIM card)
The LED lights can light up when the phone rings.And the LED lights can be turned off compeletly if you don't like it.
1.
1* Mobile phone2.1* Stereo Headset 3.1* charger4.1* USB cable5.2* Original batteries6.1* English manual7.1* Screen protector
Check out this site for more details
Jan 10, 2012 | Cell Phones
I had bought a dual xd1222 aftermarket stereo. i bought a gm2000 harness for it to hook up in my 2002 chevy cavalier. i have all the wires connected but when i hook it up in the carit will not work. what...
check the fuse behind the stereo and in your fuse box first off and make sure the power wire/ignition wires are on the correct pin. do this with a test light for verification. also check the ground wire. after you test and connect these 3 wires, the stereo should turn on. Your wiring harness may not be done correctly so visual verification with a test light would be the best thing before starting a car install. If this still does not work and the stereo you took out did, it is a malfunctioning unit.
Sep 11, 2010 | Dual Car Audio & Video
Car stereo not working and dimmer lights went out
Where is the switch so i can dim down the blue light from my stereo? and, how do i turn on the stereo beep?
Oct 22, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Dual xdvd700 has been locked, broken remote, blue screen
you have to press the reset button then it will work
Sep 17, 2009 | Dual Car Audio & Video
DUAL XDVD8181 car unit - motorized TFT screen won't come out!
Open it again and check the ribbon cable for cracks, the one that get drag in and out every time it open and close. Because it is a defect for Pioneer too, and Pioneer would replace it free. Goodluck.
Mar 01, 2008 | Dual XDVD8181 Car Video Player
Dual Electronics XDVD700 Car DVD Player Logo
108 people viewed this question
Top Dual Electronics Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
xxxxxx xxx
Are you a Dual Electronics Car Audio and Video Expert? Answer questions, earn points and help others
