Question about Poulan Garden
I HAVE A NEWER POULAN PRO CHAINSAW.STARTS AND RUNS FINE FOR 10-15 min. THEN DIES AND WON'T RESTART UNTILL COLD. THEN IT REPEATS THE SAME PROBLEM.
  • 30 Answers
If it pulls easier than it used to when you try to start, you have low compression. Once the saw warms up, it doesn't have enough compression to run. If that's the case, there is no easy fix, it needs piston rings.
Posted on Dec 16, 2016
#1 Taper
  • 1040 Answers
SOURCE: Poulan 335 chainsaw starts easily and then stalls
1. You will first want to check your fuel lines for cracks/breaks.
2. If they are o.k. then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure that the small screen in carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Check the gasket and diaphragm for breaksor wear. (NOTE): If your carburetor guts, (Carb. Kit), are more than 3 or 4 years old, you might want to replace them while you have it apart.
If you need further assistance, just let me know.
Jim
Posted on Jun 10, 2009
  • 246 Answers
SOURCE: chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Posted on Jul 26, 2009
  • 4088 Answers
SOURCE: poulan pro 42cc starts when
Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. If no help, remove the carburetor, disassemble and clean the interior with spray carburetor cleaner. Check the condition of the diaphragm in the lower chamber--it should be flexible with no holes or cracks. Also check the small needle valve that the diaphragm controls. Check the crankcase impulse passage behind the carburetor for gasket failure or other damage. This passage pulse-pumps additional fuel into the carburetor as it runs. Hope this helps!
Posted on Jan 15, 2011
  • 4088 Answers
SOURCE: husqvarna 455 rancher Starts fine and runs great
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Posted on Jan 17, 2011
Testimonial: "Fuel tank vent fixed the problem, thank you for your help"
latinoboytx
  • 46 Answers
SOURCE: I have a poulan pro 42cc 18" chainsaw that runs
you coil is intermitting. need to replace coil.
Posted on Sep 23, 2011
Chainsaw runs then dies
Carburetor needs to be overhauled and replace all fuel lines and fuel filter.
May 06, 2014 | Poulan Pro Chain Saw. 18 in. 42 cc Gas...
After the chainsaw starts up it will idle the min. you disengauge the high idle on the choke it runs for about 3 seconds and then dies like it ran out of gas
When it dies pull out the spark plug. If it is dry it is getting not enough fuel,wet is too much .Adjust the L needle till it stays running.
Jan 26, 2014 | Poulan Garden
Starts and runs fine, about five minutes then sputters and dies. will not restart until cooled
do cold comp. test if below90psi remove muffler and inspect piston cyl. wall for scroing
Oct 20, 2012 | Poulan 14" Chainsaw
Runs but the chain won't move? Poulan
This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
Aug 28, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Poulan pro 42cc starts when choked,take off choke runs almost 1 minute and dies.chock and restart same thing. will not stay running even when throttled.
Jan 14, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw starts and runs fine for a few minutes
Jul 26, 2009 | Garden
My mower starts and runs great when cold but dies when hot. It will restart but won't stay running until it cools off again.
How old is your mower ? Sounds like points and condensor if older model ,or ignition module if its newer , points tend to stick together when they get old causing no spark at plug when they cool they come appart allowing it to spark again , module is sort of the same except you have no way of replacing points you have to replace module .
May 11, 2009 | Garden
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
73 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
