Question about Belling Freezers
Hi my belling chest freezer is set at min no fast freeze light on , every few months it will defrost on its own , what am I doing wrong , thanks for any help.
fridgetech
  • 473 Answers
SOURCE: whirlpool 10cube chest freezer red light
yes.
Posted on Oct 07, 2007
  • 7 Answers
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Posted on Jan 17, 2008
jaylex
  • 417 Answers
SOURCE: Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
Posted on Feb 16, 2008
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
wheelshot
  • 102 Answers
SOURCE: Buzzing noise -Kyoto KU 9577 Freezer
you may have a bad compressor or a bad compressor relay. The buzzing noise sounds like the compressor trying to start but can't. Unplug the unit and pull the relay off the compressor. If it rattles like gravel in side it replace the relay. If it doesn't then you may need to call a repairman to check the compressor. Hope this helps.
Posted on Apr 11, 2009
Hi I have a Belling BCF10 chest freezer. The power light is not lighting but the freezer is still freezing, what is wrong? Also when should one use the fast freeze switch? Thanks in advance
If the freezer is working properly then the circuit that feeds the power to the power light is not working or the light itself is burned out. Either one or the other.
Sep 17, 2016 | Belling Freezers
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
Lost owners manual
You only require fast freeze if you are using the freezer for the first time, after a defrost, or if you add a large quantity of fresh food to an already running freezer. Most freezers require about eight hours at fast freeze. As to the temperature setting I would suggest you purchase a purpose built freezer thermometer (very cheap) and place that on top of the food. With the thermostat control set mid way (about 3 or 4) check the thermometer occasionally see what the temperature reads. It should be around -18C, if it's lower then set the thermostat lower at 2-3, if its higher set the thermostat higher at 4-5. Repeat this until the freezer temperature is correct.
Dec 26, 2013 | Haier 3.6 cu. ft. / 102 liter Chest...
I have a belling chest freezer BCF 20 ... It has an orange fast freeze switch is this switch left on all the time????
No. That is like running it on "high power" full time and could cause it to wear out and stop working much sooner than it's natural life expectancy. It also uses up more than twice the electricity on your electric bill, than it needs to work normally. That setting could also be used in something like a store, where people open it up every few minutes, to keep it cold when it's opened so often.
That switch should only be used for emergencies, like after a power outage, or to quickly freeze foods that were fully thawed and need to be frozen quickly.
Oct 14, 2013 | Belling Freezers
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
Belling chest freezer, should the fast freeze button be switched on all the time?? ice-cream an desserts are always very hard when taken out
Hi!!
No, the fast freeze button should only be activated when you load a warm or lots of items at once. It should disengage by itself after a preprogrammed amount of time. If Ice cream is too hard, check your temp. settings.
Good Day!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 02, 2010 | Freezers
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Nova scotia chest freezer - does orange light indicate fast freeze??
I have a nova scotia chest freezer on the indecater it is 0 to 5 which is the coldest number 0 or 5
thank you
Sep 20, 2009 | Freezers
Freezers Logo
89 people viewed this question
Top Belling Freezers Experts
richie46
James Coghill
Tom Chichester
Are you a Belling Freezer Expert? Answer questions, earn points and help others
