How do i use Cast button on remote - Televison & Video
Are spectron tv compatible with chrom cast device to stream movie???
Try the hdmi settings in your tv, and select different modes, eg 720i 720p ect
Jan 22, 2015 | Spectroniq PLTV3250 32 in. LCD TV
How do I get my reel to keep from letting the line out while I'm holding down the cast button?
Hold the line with your index finger and against the rod itself. Then cast and release your hold
May 12, 2014 | Zebco 11 Authent Micro SpinCasting Reel...
When releasing the thumb control to cast the line drops free (making it unable to cast)
you have to release the button after you start your cast, distance,height and length of cast is determined by where you release the button inside the forward arc of your cast, just like throwing a baseball.
Oct 18, 2013 | Zebco 33 Authentic Spincast Reel, 1 Ball...
I have a problem in my BPL TV(FHR-21) it showing a green color
How to Fix a TV When the Screen Is Green
A TV is calibrated by the factory to provide a "standard" picture that attempts to appeal to the vast number of buyers who take the set home. To adjust a TV picture that is too green, you must first enter the hidden "service menu" that technicians use. Adjusting the colors to remove the green cast will save you the cost that would otherwise be incurred from a TV technician coming to your home. No special tools are needed, nor any expertise in how the TV works.
Press the power button on the remote of a TV whose picture is too green in order to turn it on.
Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made. Turn the TV off.
Sep 14, 2011 | Audio Players & Recorders
In Rapala fishing frenzy, how do you cast? The mii can sit, stand, operate the boat but does not cast.
You know you need to have a nunchuck attached, push the kn0b on the top of it forward and hold it there, then take the remote in the other hand put it up by your head and then make a throwing motion forward and ti will cast the lure out at that time.
Jan 18, 2009 | Nintendo Rapala''s Fishing Frenzy for Wii
Need remote code
There is no code, I had to use the remote from Com Cast. So you have two remotes, one to turn it on and one to do the rest.
Jan 15, 2009 | Emerson EWL3706 37 in. LCD Television
How do you reel in a fish
Use the "B" (trigger button under the controller). Its alot easier than reeling motion.
Dec 27, 2008 | Nintendo Rapala''s Fishing Frenzy for Wii
Having problems casting
To cast the line, you hold down the A button, make a casting motion with your arm, and let go of the A button near the top of your casting arc. Reeling in the line is as simple as moving the Nunchuk in a circular motion or pressing the A button. You can move the line either left, right, or back by moving the Wii Remote in the same direction and increase or decrease the drag on the line by pressing up or down on the D pad on the remote.
check out this little girl playing the can see the motions she makes to cast:
For more info on controls, gameplay and cheat codes, visit this webpage:
On the left of the screen, you'll see box art image, further under that you's see the 'get it at best buy' and further under you will see where you can click for images, videos, and hints & cheats. Have fun! :)
Sep 08, 2008 | Activision Rapala Tournament Fishing for...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
