Question about Samsung SyncMaster 920NW Monitor
I'm trying to help a handicapped friend of mine with his monitor/computer problem. He has a Samsung 920 NW monitor. The computer boots up but the monitor immediately goes black. The blue on/off button on the monitor is not blinking. I can turn the monitor off then right back on and see the screen for about 1 second when the screen goes black again. Help?
    President:
  • 1,996 Answers
Here's a good link to a troubleshooting guide for monitor problems that may help you to correctly diagnose the cause. Another article and other links here as well) I'd hook the monitor up to another system for starters to see if it works there...
Be sure to check the monitor cable. And if another monitor works on the same system but that one doesn't, check that the settings are all correct for that monitor, including resolution, refresh rates, etc.
This could be also the result of some kind of hardware conflict at boot, a bad graphic card or outdated driver (in which case here's a tutorial to help you update the driver), or even malware in the system, in which case I recommend you follow these protocols to scan for and remove the malware....
And sometimes monitors just wear out, particularly if they're not setup to run in optimum conditions...
Posted on Jul 20, 2009
    Problem Solver:
  • 17 Answers
The graphics card could be burned out.
test the computer with a different monitor
if the same thing happens it ts one of 2 thinga; dead graphics card or virus
I have a Samsung Sync Master 920 NW model number 920nw, model code LS19HANKBM/XAA. The Monitor will not turn on but the power button blinks. I have tried to bring it out of standby but nothing works.What...
This type of problem is caused by a failure of the filter capacitors on the power supply board. The board is easily repairable, you just need to replace the defective capacitors. It will require a little soldering but anyone can do it. Here is a link to a repair guide showing how to repair the board and what parts and tools will be needed to complete the repair. I hope this helps you out.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
Apr 12, 2013 | Samsung SyncMaster 920NW Monitor
Amigo handicap scooter -- loosing distance with in use
you'll need new batteries plan on replacing them at 1-1/2 to 2 years
Oct 14, 2012 | Amigo Health & Beauty
Jharris39@sbcglobal.net I have a Syncmaster 225 BW that became intermittent and finally just went gray and flashed between "analog" and "digital". I them borrowed a Syncmaster 920...
When you tried the replacement monitor, did you have the pc turned off when you connected it, if not then restart the pc and it may work. I realise you probably already have but I don't have that info.
Anyway try both monitors with a computer that is known to work properly (make sure it's off when you plug them in), if both monitors don't work then it's a monitor prob, if one does and the other doesn't then you know one monitor isn't working and if you still can't get the other one to work with your pc then it would suggest that you also have a video problem.
Sounds like the original monitor may have a prob with the inverter or control board, it may even be some bad caps or even a switch (unlikely but possible), but it could be explained by a video problem. So narrowing down where the problem is, is the first step.
Hope this helps you out. Once you've found out where the problem is, you could post back and see if someone on here can help you fix it.
Here's a link, in case you find out it is monitor related, it would help with all the possibilities I mentioned.
http://www.badcaps.net/forum/ - you'll want the section on troubleshooting computer displays
Feb 16, 2011 | Samsung Computers & Internet
I have installed Windows 7 in my Pc with the monitor Sync Master 920 NW and the maximum resolution available 1280 X 768 when the max resolution of the monitor is 1440 x 1024.
Download the correct graphics driver.
If you have a Graphics card, download the driver from either Nvidia or ATI.
If your graphics chip is on the motherboard, download the driver from your manufacturers support page
Aug 05, 2010 | Samsung SyncMaster 920NW Monitor
Moritor turn off after 3 second
problem with power supply circuit or inverter and ccfl lamps..
May 17, 2010 | Samsung SyncMaster 920NW Monitor
Syncmaster 920 nw lcd monitor dispaly problem
sounds like your having pixel issues I would advice calling up samsung and checking there pixel policy if it is out of range they will need to replace it
Dec 16, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Doesn't show anything !
It could be either your graphics card or your monitor ,try the monitor on another pc if you havn't got one try a Friends.It also could be a loose lead check the leads are inserted correctly.
Aug 06, 2009 | Philips 170S7FS 17" LCD Monitor
My keyboard keep blinking
hi im josh in cebu phils.may i help you friend? just try this solutions o mine this will help you.
ry re-seating the video cable. Try another monitor on this computer if you have one available. Try this monitor on another computer. That will narrow down where the problem lies. It's either the video card or the monitor which is bad. Of course if either is under warranty you may get a replacement, if not get your credit card ready :-)
I would also look at the cable connection and see if there are any bent pins. This has caused issues for me in the past. Just be careful rebending the pins if any are bent. They are fragile and may snap off. good luck friend
Mar 05, 2009 | Compaq (158272-001) Motherboard
Samsong syncmaster 920 nw
replace the power supply to the pc if the fan is not working it could be overheating and causing it to shut down.
Nov 13, 2008 | Electrical Supplies
Samsung SyncMaster 920NW Monitor Logo
207 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
