Question about Avital Vehicle Parts & Accessories
I have an avital 5303 remote start system with alarm.For whatever reason I cannot disable it so that I can simply start the Honda SUV with my key.What should I do now?
IrishDruid
  • 2712 Answers
SOURCE: 1995 Jeep Grand Cherokee Laredo Alarm system
Solution 1
1) Remove the driver door panel 2) Remove the lock 3) Remove the switch from the back of the lock 4) Pull the switch cord assembly to the bottom of the door cavity 5) Unplug and remove the switch assembly from the car 6) Either (a) short the female end of the plug, or (b) ground the striped wire to the car door.
Solution 2
Normally, you would insert the key in the drivers door, turn left, then right to disarm and reset it. If yours is malfunctioning, you can disable it for good by doing the following:
The FACTORY ALARM DISARM WIRE IS purple/yellow |-| in the driver kick panel area, at the black plug.
Once Located, splice into this wire with a simular guage wire, and put it to a solid chassis ground. This terminates the alarm functions entirely.
Solution 3
Go to the passenger side door and lock/unlock 2 or 3 times to deactivate the alarm switch in the door latch. If battery is weak/low it wont solve problem, must replace battery.also check for broken hood pin switch($5.00) as they are likely to be broken on a 94 veh. and when failed will cause security system to activate causing security light on dash and no start condition/lights flashing etc
Posted on May 14, 2008
ltfrc
  • 227 Answers
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Posted on Jan 28, 2009
SOURCE: can't lock my Honda Accord as alarm goes off when locked
if you have a valet key, stick it it on the passenger side when unlocking door, so it wont alarm while you open the door hope that helps
Posted on Sep 06, 2009
wfservices
  • 262 Answers
SOURCE: 1996 Explorer anti-theft system won't disable
Try re-setting the computer...Disconnect the negative terminal of the battery and leave off for 5-10 minutes. This will allow the computer to reset. The charger may have interupted the signal or something.
Posted on Mar 11, 2010
logosc75
  • 625 Answers
SOURCE: i have a problem with
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Posted on Feb 25, 2011
I have a 98 GMC Yukon I need to uninstall a 5303 model Avital aftermarket alarm system/keyless remote. I believe it has malfunctioned and is causing my car not to crank. It will turn over but no spark
Try finding it. Under dash probably.. Unplug the two fuses first, sometimes that works, if it's a high end viper or dei unit then you can trace the wires to the starter. #12 gauge wire pink or red. Should see where it's tapped in or relays hidden under the panel. It shouldn't cost too much for electrical guy to find and disable
Sep 08, 2015 | Avital Vehicle Parts & Accessories
When I tried to unlock my car with my remote it would not unlock the car, I used the factory remote that came with my car, the alarm went off and would not go off. We had to pull the fuse out to get i
You can put the alarm in valet mode so it's inactive. There is a pushpurltron switch il under your dash all you need to do is turn the ignition on and within 10 seconds press that button once then turn off the ignition. Link to a owners manual http://www.manualslib.com/manual/13567/Avital-5303.html?page=21#manual
Jan 29, 2015 | 5303L 2Way LCD Remote Start Security...
Disable timer on avital remote control
i think the engine rev needs to be turn down a little
Jul 14, 2014 | Hardware & Accessories
Avital alarm wont lock or unlock doors
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
Mar 03, 2014 | AviStart 5303 2-Way Security / Remote...
Avital 5303 kills engine while driving 1998 honda civic
you check to see if the engine was hot or something like if the water level in the radiator was down the sensors in the security system would pick it up
Jan 27, 2014 | 5303L 2Way LCD Remote Start Security...
Uninstalling a remote starter/ alarm system in a 1997 Yukon
Depends on the type of remote. Most common fix 1. Take off the lower drivers side kick panel. 2. Locate the black remote box. 3. You should see a thick yellow wire coming from the steering wheel area that has been cut and then spliced to go into the remote box. This is the feed to starter relay and will have voltage when key in in start position.4. reconnect the yellow wire back together bypassing the box. 5. Find the red wire( power source) that goes to box and disconnect it.
System should be bypassed
Oct 30, 2013 | AviStart 5303 2-Way Security / Remote...
I need to know how to wire a led scanner to an avital 5303. The light has a red pos, black neg, and yellow that says brake. i want it to come on when the alarm is activated
Forget the yellow wire. Its for wiring WITHOUT an alarm. Connect the red to a fused 12 volt and the black to the orange "ground when armed" of the Avital 5303.
Jan 21, 2013 | AviStart 5303 2-Way Security / Remote...
How do i reset my remote start car alarm avital 5303
i have a avital 7352l remote start my fob got smashed under the hood of my car still locks and unlocks car but went to use remote start and it tried to start car but it didnt then i got into my car and try to use my key and it didnt crank at all can anyone help me solve this problem?
Feb 21, 2011 | 5303L Security/Remote Start System
Vehicle Parts & Accessories Logo
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
