Question about Health & Beauty
Got a pronto for friend its new but has Been sitting over a year and will not charge. Is there anyway to charge it or do I have to replace the batteries?
  • 280 Answers
Unfortunately you need to replace the batteries.
Posted on Dec 15, 2016
Pronto MC1 chair stopped running; battery plugged in
charge48 hours at first then at least 2 hours for 1 hour of use.- 4 years is a long time stored batteries may be bad
Nov 22, 2012 | Invacare Supply Group Pronto M61 Standard...
I have added new batteries to my pronto m51 when i went to charge i am getting a flashing green i think it should be yellow?
recheck your polarity on the batteries carefully, i've done it for 15 years and the factory makes it complex sometime i connect backwards initially
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
O have a Pronto M 41 and was bought in 07 but am having problams with turning on and shutting off.Could you tell me what it could be.
Have you replaced the batteries ever? I was told by my local Invacare vendor that the batteries are only good for 12-18 months. My mom's Pronto M41 was having battery problems and replacing both batteries solved the problem in her chair bought in 2007. Now she is looking to buy a slightly used chair (4 mos old) from the family of a deceased friend and there seem to be issues with the batteries in this almost-new chair.
Sep 11, 2011 | Electric Mobility Invacare Pronto M41...
My pronto m41 was not used for about 3 years. I need it desperately now except service light is on and scooter no go! Does "service" mean to clean, check bolts, connections, look for fraying...
Hi I would invest in some new batteries ...if they have been in the chair for 3 years without charging them they r no good :::::: when batteries sit 4 a long period a coating forms on. The cells .when this happens they will never charge properly again ..cheers
Mar 03, 2018 | Electric Mobility Invacare Pronto M41...
I have a Pronto M6 wheelchair that is not working. I called technical support and they suggested it needed new batteries and that the batteries should be replaced yearly. I installed the new batteries...
Make sure all of your connections are tights and the your fuses do not need to be replaced.
Blinking lights on the controller usually indicates a problem, the number of blinking lights are used to diagnose the problem. Take a look at this website to identify the type of controller you have on your scooter so you can dtermine what the blinking lights are trying to indicate.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Oct 12, 2010 | Invacare Supply Group Pronto M61 Standard...
After receiving this particular chair I had surgery and was not able to operate chair with my hand. The batteries were brand new and fully charged at the time but now have sit for almost a year. Now that I...
imwaltz Sorry buddy but if it sat that long the batteries are probably too low for the charger to pick up and charge. to bad you didn't just charge those batteries once a month while you were laid up. You will have to get new batteries. If Medicare paid for your chair they will pay for most of the repair costs. Contact Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 these are 2 excellent service companies that will bill Medicare for repair and have a tech repair the chair for you. Hope this helps
Oct 11, 2010 | Invacare Supply Group Invacare Pronto M91...
PRONTO M51 FEELS LIKE I AM DRIVING OVER ROUGH ROAD AFTER REPLACING THE BATTERIES. WHY?
If you chair was down for a long time before getting new batteries the tires could have developed flat spots on them. Also could have brush problems in the motors that make the motors run jerky from sitting too long.
May 02, 2010 | Invacare Supply Group Invacare Pronto M51...
I need a new battery where can i get a low
The batteries inside the small hand held are NOT consumer replaceable. They are all soldered in place. If you are a handy with a soldering iron, you can replace the batteries yourself. I did and my Pronto 2-1 runs like new. I had it for about a year then it gradually lost its holding charge. I would only get about 2 minutes before it stopped.
Battery Replacement. First you will need new batteries. The batteries for the Pronto 2-1 are called NiMh 4/5 Sub C 2000mAh w/ TABS and can be purchased at Batteryjunction.com. You will need 8 of them. I paid a total of about $30 shipped. Next. Remove the 4 small screws holding the unit together. Once you have it apart you can get an idea of what is ahead. It took me about 45 minutes to cut out the old batteries and replace with new ones. Here are some helpful tricks. Use a knife to cut off the tab jacket about ¼ inch from the ends on all of the new batteries. Use a pair of needle nose pliers and tear off the battery tabs right off the OLD battery bodies. Replace the batteries ONE AT A TIME except for the group of 4 in the handle. The goal here is to solder the new battery tabs to the OLD battery tabs. This is much easier soldering tabs together than stripping and soldering the wires. REPLACE the batteries exactly how you see them. Add electrical tape where appropriate. Be careful when packaging the batteries back in place. I mentioned replace the batteries one at a time because this will allow you to verify your soldering. Press the on button and you should get the blower going. If not, you have a bad solder joint. Anyway, good luck. Jeff
Jul 20, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Can't charge Pronto M91.
Hi Bob. Unfortunately in most cases this means that the batteries have gone so flat that they cannot be “revived”. The best thing to do is take the batteries to a local battery dealer and have them checked. You may need to replace them. Another possibility is that because the batteries are so flat, the charging circuit hit a wobbly trying to resuscitate them and popped a fuse button. A simple reset may help. Happy scooting. Regards Chris… info@mymobility.co.nz
Jun 21, 2009 | Invacare Supply Group Invacare Pronto M91...
Health & Beauty Logo
94 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
