Question about Humidifiers
New 9500 series essickair humidifier. Unit is full but "F" won't stop flashing.
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
Jan 17, 2016 | Humidifiers
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Need essickair humidifier manual
Follow the provided web link. Select from the appropriate category of humidifiers by Essickair, then click on the "More Info" link after which you should choose the specific model humidifier that you own. After doing so you will find a link to the lower right(under "Resources") saying "Owners Manual."
Clicking that Owners Manual link will allow you to open and/or save your humidifiers manual.
Oct 18, 2013 | Honeywell HE360A1027 Whole House...
Someone gave me moistair 14060 do you have manuls so i know how make it work
Years answer appears!
I have the MoistAir HD-14060, also without a manual. Other than the controls, which are now electronic, this appears to be exactly the same; you can download the manual from the page:
Sep 12, 2011 | Emerson HDC12 Humidifier
I need to verify that these are calibrated at the factory prior to shipment. if so i need documented proof.
James, I suspect that only the manufacturer can verify and provide documented proof of that, You can contact Customer Service @ 800-547-3888 or you can email them @
Apr 14, 2011 | Essick Air 4D7 300 Humidifier
These hints are from the air o swiss webpage.
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
If your issue is with the float and not the mister, then you have to make sure the float is tripping the micro switch that turns the machine on. Some units the filter will not allow the float to hit the switch if the filter is not installed correctly. If everything is in correctly and the float is tripping the switch, then the micro switch must be faulty.
Apr 04, 2011 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
Water flow to my humidifier wont stop. and the pump is constanly running.
Sounds like the float valve inside the water holding tank is stuck in the open (down) position. Unplug the unit and take the cover off the tank portion of the humidifier. Look inside and you will see the float valve, if it's in the down position, manually lift is up. If it stays in the up position the incoming water should stop, The next thing is to determine what caused it to get stuck? Is there some sort of debris in the tank? Is the float lever rod bent or out of place? Does the float on the end have a hole in it and is full of water? These are the things you need to start with in troubleshooting the unit.
Hope this helps to get your started in solving the problem.
Mar 11, 2011 | Aprilaire 550 Humidifier
Humdifier on furnace
I have the exact same problem. At this time I am looking for a new solinoid (part on the bottom) to install. Anyone else having this problem and know where to find replacement parts
Jan 22, 2008 | Aprilaire 700 Humidifier
Here is the link for the user manual for your humidifier; If you don't find what you need in there then try; Hopefully they should help. If you still get no luck then please post back again with some more details of what you are having trouble with, maybe post some photos as well and we can try and help :)
Mar 24, 2007 | Essick Air 4D7 800 13 Gallon Humidifier
Humidifiers Logo
Top Humidifiers Experts
Paul Carew
Are you a Humidifier Expert? Answer questions, earn points and help others
