Got double image logo y - Televison & Video
Identifying bathroom whirlpool bath manufacturer by logo
maybe you could photograph the logo and then go into google images and search the photo image against googles massive list of images to see if a match can be made to it
Aug 22, 2016 | Whirlpool 5"x36" White Bathroom Drop-in ...
Answers to logo quiz
There are a number of Logo Quizzes on the market, and finding a specific version can be tricky. This is usually for enthusiasts of visual merchandising images, who like the challenge of recalling and finding the logo that is formed by the partial image given.
If all else fails, you can start looking in:
www.logo-quizanswers.net/
Hope this helps.
Nov 04, 2013 | Computers & Internet
I have a 30 inch wolf range I took the door off of. I'm trying to take the door apart but there are 2 screws behind the logo plate that need to come out. The problem I'm having is getting the logo plate...
A plastic putty knife can help, but the logo is held on with double sided tape and the Wolf parts book always says to order a new logo whenever you order anything that requires removing the logo
Aug 07, 2013 | Wolf Range WKGD-2 Gas Double Oven
How do you replace the Dell logo at the back of your lid? I want to make my own physical image (probably glowing) and put it at the back of the screen but I'm not sure if it's possible to remove the native...
The Dell logo you see at the time booting is the logo of your motherboard manufacturer. It uses the image associated with the program that helps you in booting your computer. If you want to change it, you should have proper knowledge of computer programming and IT. All you need to do is to identify the proper programs associated with the Dell logo and then hack the corresponding .exe or .dll files and replace the image with your own one in correct image format.
Hope this helps,
Mrityunjay.
Apr 03, 2011 | Dell Latitude D610 Notebook
I want to change operator logo in my nokia 2730c. Plese tell ne procedure.
It is so easy.just click on your mobile (max3d.wapka.mobi),then go to operator logo and edit the url and submit it.The op logo is automatically send in mobile.You can set any image to logo just go to filehosting web and upload a image.Then uploading url edit on max3d.wapka.mobi in operator logo option and enjoy it
Aug 23, 2010 | Cell Phones
Picture has blue at the bottom and yellow at the top. Double images and the station logo is in the wrong place
This tv have convergence problems.Tries website Tvrepairworld.com to buy the whole refurbish convergence board for the replacement.The Samsung/Akai used the same convergence board.
May 15, 2010 | Samsung HCN4226W 42" Rear Projection...
Picture has blue at the bottom and yellow at the top. double images and the station logo is in the wrong place
Sounds like your convergence ICs are bad. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to correct it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 28, 2010 | Samsung HCN4226W 42" Rear Projection...
HP 1410v all-in-one scanner won't work
Please follow the steps given below to scan from other applications.
Windows XP:
Scanning from Microsoft Paint:
1. Click Start, click All Programs, click Accessories,
and then click Paint.
2. Click File and then click From Scanner or Camera.
If this option is not available, Please let me know.
3. If more than one image source is connected, select the
HP all-in-one product and click Next. The scanning software
will appear. Preview the image by selecting Preview,
or click "Scan" to scan the image directly into Paint.
4. The image will open in paint for editing and/or saving.
Using Windows Image Acquisition (WIA)
Verify that the all-in-one product power is turned on and the printer cable is properly connected.
1. Click Start.
2. Click Control panel.
3. Click Scanner and Camera Wizard.
Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If it is possible to scan from any of the above methods, try to scan from HP schortcut File and get back to me with the results.
Scan Shortcut:
1. Search for the file hpqscnvw.exe
2. File should be available in the following location
C:/Program files/HP/Digital Imaging/Bin folder
3. Create a shortcut on the desktop and double click the same
to activate the scanner and try scanning.
Windows Vista:
Scanning with Windows Photo Gallery
1. Click the Start ( ) icon.
2. Click All Programs
3. Click Windows Photo Gallery
4. Click File and then click Import From Scanner or Camera
5. Click Import
6. Click Scan
Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate,
Windows Vista Business, and Windows Vista Enterprise.
1. Click the Start () icon.
2. Click All Programs.
3. Click Windows Fax and Scanning.
4. Click New Scan.
5. Click File and then click Scan.
Scanning with Paint
1. Click Windows.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Scanning from Shortcut File
* Click on the Windows logo to access the start menu.
* Click on Computer.
* Double click on C:\drive icon.
* Double click on Program Files folder.
* Double click on Hewlett Packard or HP folder.
* Double click on Digital Imaging folder.
* Double click on the bin folder.
* Locate the hpqscnvw.exe file and double click on it.
Vishwanath V U
May 19, 2009 | HP PSC 1410v All-in-One Printer
Resizing an image in a layer
i know what you are talking about when you say your losing quality. This is how i fixed it and it worked for me.
Try this:
Image, Resize, Image size
Check the settings in here.
Is "Resampling Image" turned on or off?
I turned mine off and it worked for me.
Printed pictures of Starbucks coffee cups at 1" tall and the logo was dead on still.
Hope this helps.
Good Luck.
Apr 09, 2008 | Adobe Computers & Internet
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
