Question about Vacuums
It will not pump water onto the carpet - Vacuums
  • kakima Dec 11, 2016
    Hi ben smith, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is "it"?
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
How do I fix the problem on my Bissell model # 7920-5 carpet and floor cleaner the water won't spray out onto the carpet
First check your user's guide for filter cleaning. There are two filters both small that need cleaning after each use. If that didn't clear it up call Bissell Consumer Care at 1-800-237-7691
Jul 01, 2014 | Bissell Vacuums
I have a Hoover carpet cleaner that leeks the shampoo water onto the carpet, cannot control it
The machine is standing in the upright position with clean water in it. No power to the machine. If water is pouring out, again no power to machine, then the pump is cracked. I don't know the model number so I am thinking this has a gravity fed pump. It doesn't use electricity to work the pump. Once you pull the trigger water starts to flow. If the pump has a crack water will flow all the time. Hope this helps!
Jun 16, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
New bex bissel wont release water onto carpet
Hey Margart! I understand how frustrating it is to have no spray when trying to use a machine.
We have a terrific list of FAQ's on our website to assist you. Here's a quick link: http://www.bissell.com/faqs/?cid=ccsocial
Feb 09, 2013 | Vacuums
Cleaner wont release or **** up water off the floor
There are a few different problems this could be. Usually when someone says it won't extract water off the floor it is because it is not squirting any water. If it is not doing either then you have more than one problem. You can try to pour some water from a cup onto the floor to see if it is extracting water from the carpet. water not squirting could be clogged jets. Look underneath at the red jets and make sure they're not covered with hair or dirt. You can remove and clean them. It could be the pump is not working properly. On some Bissel units the pump has a cogged belt that turns the brushroll. If sometihing gets caught in the brushroll it can strip the teeth off of the pulley on the end of the pump which means you have to buy a whole new pump. Another problem I occasionally see on this unit is the pump gets full of soap suds and will not pump water. Sometimes I can get it working agian by removing the lines and flushing out all the suds.
Jul 18, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
No water
check the pump belt that runs from the brushroll to the pump. frequently the plastic gear on the pump wears out. the pumps also frequently fail. check all solution supply lines for cloggs, and most importantly check the spray nozzles inside the unit by the brushes for cloggs. let me know if you need any further instructions. thanks,
chuck
Jan 07, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
Nov 14, 2008 | Kirby Vacuums
.7950BISSELL PROHEAT.PROBLEM IS NOT PUMPING
My Bissell Proheat carpet cleaner doesn't pump onto the carpet. I don't have the instruction booklet.
Thanks.
Jul 06, 2008 | Vacuums
Vax problem
Could be a bad pump.
Feb 07, 2008 | Vacuums
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
