Question about Garden
2 stage 1 year old with hours running time won't run with the choke off
2 Suggested Answers
jimflower89712
  • 903 Answers
SOURCE: 2 stage craftsman snowblower1 year old with 5 hours running time won't run with the choke off
it is a carburetor issue. inside the carburetor the fuel gums up especially in seasonal equipment as snowblowers. look inside the bowl and see if there is any water. take it off and clean it real good with carburetor cleaner. it will run like new.
Posted on Dec 11, 2016
Dec 11, 2016 | Craftsman Garden
Bike only runs with 1/4 of choke out.
Hi, Syed you have inadequate fuel delivery somewhere in the system if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly then stall, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 2-3 years old when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and the battery needs to be replaced.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove and inspect your air cleaner paper elements that are not oil soaked can be cleaned with a soft brush and low pressure compressed air, oil soaked elements must be replaced. Gause mesh and foam elements can be cleaned by soaking them in a container big enough to completely cover them with a solution of 1 gallon of water and 1 oz. of Dawn dishwashing liquid for small and medium size elements, for monster size double the formula and let soak for at least one hour then rinse with warm water shake off excess and let air dry, "WARNING" do not use compressed air as this will embed micro-sized dirt and road grime and destroy the mesh pattern and stretch foam elements out of shape just squeeze it like a sponge and let air dry, use a fan if you're in a hurry. When completely dry spray a very fine mist of air filter oil evenly around the whole element.
6. Remove the carburetors, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove, clean, and inspect fuel and vacuum lines and replace as necessary.
8. Replace spark plugs with new ones and check for spark.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Need Help Bike won run choke in
http://www.vt750dc.com/HONDA_VT750DC.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://www.vt750dc.com/VT750DC_OwnersManual.pdf
Jul 27, 2016 | 2008 Honda VT 750 Shadow
2009 hyosung gv250
Hi, Anonymous if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will not idle unless the choke is full on and run poorly then stall, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition and in the future pour in a bottle of fuel stabilizer and injector cleaner for you FI folks at least 2 times a year and before storage.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or more, any readings in the 11 volt range you need to do a proper "LOAD" test on the battery and replace as necessary, you may have 12.5 volts or better but little or zero amps, any readings in the 10 volt range you have a dead cell and the battery needs to be replaced.
7. Check intake manifold and seals for leaks and cracks.
8. Remove fuel valve and filter disassemble and clean as necessary, remove, clean, and inspect fuel and vacuum lines and replace as necessary.
9. Replace spark plugs with new ones and check for spark.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://korider.com/index.php?topic=13596.0
Bike won Run without Choke
Hyosung Aquila 250 Service Manual
https://www.alpha-sports.com/Parts/H_GV250.htm
HYOSUNG GV250 User Manual
May 13, 2017 | 2009 Hyosung GV 250
1997 Honda CBR 1100 XX Super blackbird only runs with choke
4. Drain and flush fuel tank if it rusty there is a cheap and easy fix. https://www.youtube.com/watch?v=fUYr_7SwGms
6. Remove the carburetors, disassemble and decontaminate with a "CARB DIP" or if you have EFI remove injectors and clean with carb spray and compressed air
7. Check intake manifold and seals for leaks and kracks.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
F3 won idle without choke CBR Forum Enthusiast forums for Honda CBR Owners
http://www.beginnerbikers.org/showthread.php?18094-runs-only-on-choke-dies-when-given-throttle
1997 1998 Honda CBR1100XX Service Repair Workshop Manual Download Download... $15
Honda CBR1100XX Owner Manual
Apr 19, 2013 | 1997 Honda CBR 1100 XX Super blackbird
I have a 24" snowblower that surges after 1 minute of running, after 3-4 minutes stops and will not restart until several hours later, does the same thing over and over
This sounds like a choke issue. Do you have a choke on that engine?
The purpose of a choke is to allow for a varying air:fuel ratio depending on how hot the engine is. A cool engine needs a more rich mixture of fuel to air. Once the engine warms up, it runs best with more air. The Choke is a mechanism that allows the operator to manually adjust this mixture. Generally, the choke is closed to start a cold engine, then is opened in 2 or 3 stages as the engine warms up. As the operator, as the engine starts to run smoothly, you would actuate the choke to the next notch, changing the fuel:air ratio so more air is mixed in with the fuel. It's probably best to give the engine a few minutes to warm up while you progress through the choke stages until it's fully open providing the best mixture for operation prior to beginning to clear the snow.
If you follow that process and the engine stalls when the choke is opened, then you need to clean your carburetor.
Oct 18, 2012 | Garden
'07 klr 650 won't run without choke on
Hi, Lance and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Won run without choke
KLR won idle without choke backfires on decel
Kawasaki KLR650 Service Manual
OEM Parts for Kawasaki
Kawasaki KLR650 Owner Manual
Jul 01, 2017 | 2007 kawasaki KLR 650
1980 Yamaha xt250 won't idle without the choke being on
Hi, Earthquakeau and the usual suspects are:
Older XT250 Won Run Some Choke
Yamaha XT250X Service Manual
OEM parts for Yamaha
Yamaha XT250 Owner Manual
Feb 14, 2011 | 2008 Yamaha XT250
I have a 17 year old snowblower. Sears Craftsman 3 HP single stage. It wouldn't start. I changed the spark plug and now it started but it's running very rough with excess smoke. If I press the gas...
Good to hear you got it running anyway.
Look for a choke, maybe it's just running with the choke set. Could also be that it's all gummed up from sitting, if that is the case then some running should bring it out of it by the time you've put a couple of tanks of fuel through it.
Is this a two-stroke motor? If so, be sure you have your fuel mixed correctly- go by the manufacturer's statement concerning how much oil to how much fuel, never assume that the oil bottle directions apply to your machine because they probably don't.
Good luck with it,
lp
Dec 28, 2010 | Craftsman Garden
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
