Question about Kitchen Appliances - Others
What is causing the pilot light to go out on my Pitco deep frying the thermostat and gas valve has been replaced
burzerko
  • 254 Answers
SOURCE: Pitco Fryalator
This is caused by a failing pilot safty bypass inside the gas valve itself. You will need to replace the gas valve.
Posted on Aug 28, 2008
  • 3 Answers
SOURCE: GAS VALVE TIMING OUT
I had a simular problem. The gas company disassembled the pilot light and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Posted on Oct 29, 2008
  • 125 Answers
SOURCE: Imperial deep fryer IFS40 pilot lights, turn on
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Posted on Feb 21, 2009
97F350diesel
  • 1326 Answers
SOURCE: I have a Pitco 35C+S
With the thermostat on the burners are still getting gas. that's normal. If it lights with the thermostat off you do have a severe problem. (bad gas valve/Tstat). The pilot does occasionaly go out on all no electronic ignition items is normal. Follow the remommended steps for relighting and if it lights fine your ok.
Posted on Aug 15, 2009
kebah
  • 684 Answers
SOURCE: I have a 40c+ss pitco fryer.the pilot will go out
Check if your pilot flame sufficiently heats thermopile during operation and make sure also that it is free of soot or any form of dirt, thermopile generates small amount of electricity to energize pilot and main valve of the gas valve for pilot and main burner operation. This electricity passes through hi limit mechanical contacts. Hi limit on fryers act as safety device which will shut down pilot and burner flame when oil temperature reaches 450F.
If your fryer is set at 350F and over shoots up to 450F (which will trip hi limit and shut down pilot and burner flame), the thermostat is not good, but, if hi limit trips on temperature much lower than 450F, hi limit is bad.
Posted on Jun 08, 2011
HELP PITCO FLAMES OUT BLOWS OUT PILOT LIGHT CAN WORK FOR 3 OR 4 TIMES SHUTS DOWN NICELY THEN WOOF SMALL BLOW BACK CAUSEING PILOT TO BLOW OUT THEN HAVE TO WAIT 10MINS TO RELIGHT
This is caused by a pressure problem. There should be an adjustment screw on the gas valve regulator. Also, make sure the pilot orifice has been removed and cleaned. There is also an adjustment screw on the gas valve for the flow of gas to the pilot.
Jan 05, 2015 | Pitco Frialator 35CD Deep Fryer
Pilot won't light at all on Pitco Frialator.
Would not be a good plan to do this your self gas valve replacement is a gas fitters job
May 25, 2012 | Pitco Frialator 35CS Deep Fryer
I have a sg14s pitco fryer. Gas valve was bad so i installed new one. Pilot lights fine but when you put gas valve in the on position burners immediatly lights. What is my problem? Thermostat and limit...
Hi there!
When you turn the gas valve knob to "on" position, burners should not fire-up if the thermostat is "off", if it does, the thermostat's mechanical contacts inside may be shorted (will not be able to control temp anymore) and must be replaced with a good one>
Regards.
Nov 10, 2011 | Pitco Frialator Kitchen Appliances -...
.poilit light on but not burnner on even i turn
Check if the gas valve knob is set at "ON" position after lighting the pilot. Check also it the thermopile is receiving enough heat from pilot flame and try also to tighten all wiring connections on gas valve, thermostat and hi limit. If these do not seem to correct the problem, you have to replace the thermopile.
Feb 28, 2011 | Pitco Frialator SG14 Deep Fryer
Lighting pilot light
Pilot assembly is located inside the bottom compartment, between the the two middle burners while the gas valve is located under the burner manifold. Make sure that the gas line where the unit is connected is open. You need to turn the gas valve knob to "Pilot" position and depress it (to allow the gas to flow on pilot) then light the pilot assembly using a lighter with extended nozzle ( burner igniter). Once the flame is present at the pilot assembly, wait for about 15 seconds (allowing thermopile to heat up) the gradually release the gas valve knob. If the pilot flame is stable, turn the gas valve knob to "ON" position and set the thermostat to desired temperature setting. This will ignite the burners and heat up the oil to set temperature. Just remember, do not do this if there is no oil on fry tank.
Feb 18, 2011 | Pitco Frialator 35CS Deep Fryer
Pilot light works but gas wont turn on.with temp guage turned up?
Check if you have turned the gas valve knob to "on" position after lighting up the pilot. If so check for the continuity of the thermostat terminals using an ohm meter. If the thermostat is good, try replacing the thermopile, if it does not correct the problem, try replacing the gas valve. Make sure that the unit receives sufficient gas pressure and volume before doing part replacements.
Feb 05, 2011 | Pitco Frialator SG14 Deep Fryer
When pilot is lit and white dial is turned to ON, fryer will not ignite when the temp dial is turned from off to 350
Make sure the knob on the gas valve is turned to the ON position after lighting the pilot. If the fryer won't come on.... 1. The pilot flame may be weak causing low millivolts. 2. The thermostat is failing. 3. The pilot flame may be good but the pilot generator may be weak causing low millivolts. As this unit operates on less than 1 (one) volt DC.... you can try to jump the thermostat leads on the gas valve to see if it comes on. If it does... change the thermostat.
Tom
Aug 05, 2010 | Pitco Frialator SG18S Deep Fryer
I cant find the way on how to light uo the friar.
If you have a pitco 35 fryer, all you need to do is have gas connected and turned on, rotate the know on the gas valve to the pilot position, depress the knob, while holding the knob down light the pilot, normally located in between the burner tubes in the middle of the front of the fryer, hold the knob for 60 seconds, when you release the pilot should remain on. If it does rotate the pilot know to the "on" position, from this point the thermostat should control the fryer. If your pilot does not stat lit, press the red button on the hi-limit to reset it, it could be tripped and this would cause the pilot to not hold. Hope this is helpful.
Mar 18, 2009 | Pitco Frialator 35CD Deep Fryer
Pitco Fryalator
Aug 11, 2008 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
83 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
