4 Suggested Answers
  • 27 Answers
SOURCE: Blinking Cycle Light
Most likely a faulty door interlock switch...try closing the door with more force, or pressing the door while trying to start...if this works it may be time to find a door lock in the meantime... Oshie
Posted on Jun 26, 2007
  • 253 Answers
SOURCE: printer won't print. amber light blinking.
try to power off printer remove the AC adapter, and hold down power button for 30 seconds, then plug in AC Adapter and power on, that may "Reset" the printer. You may be having an intermittent hardware failure. Let me know if this doesnt work. Thanks for any votes
Posted on Mar 30, 2009
  • 4 Answers
SOURCE: hold light blinking, check engine light on, engine slows down
check tps sensor (throttle position sensor in backside of the throttle cable) and map sensor (manifold absolute pressure on front little 1 inch sensor with vacuum line) make sure there plugged in. the ecm (engine control module driver side inner fender) and tcm (transmission control module under dash) both need the data to know when to upshift and increase fuel/air. Otherwise the computer runs default values and guesses off of other sensors giving poor performance. also disconnect battery for 15 min. usually resets aveo service lights if you dont have a scanner.
Posted on Aug 02, 2009
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS
9. Press the PLAY button.
Apr 16, 2014 | Tascam DP 008 Digital Portastudio
When i reboot my Zmodo dvr I Can't get menu to come up or mouse to work HDD light keeps flashing,blinking hdd light,HDD indicator light
I had the same problem. Did their online tech support and Patty told me to hold down the "rewind" button on the DVR for 20 secs. You should now be able to right click your mouse to access the on screen menu. You will now want to go under system, and a/v setup and change the device to VGA instead of Vout. Now you can reboot and not have to go thru holding down the buttons anymore. Worked for me.
Oct 02, 2012 | ECHO1USA Zmodo 4 Ch Complete Dvr Kit -...
Blinking power LED linksys
If the power light is blinking then you can try to reset the router.
Press and hold the reset button on the router for 30 seconds. Release the reset button and wait for 30 seconds. Unplug the power and plug it back in. Wait for 30 seconds.
Check the status of power light on the router.
Jan 02, 2012 | Linksys Computers & Internet
Logitech m205 won't work, the light keeps blinking
If your unit is a wireless keyboard only, then there is a button on the bottom of the keyboard and another on the receiver that is plugged into the usb port of the computer. In order to calibrate the system when it looses its signal, you have to press and hold both buttons down at the same time for 30 to 45 seconds. That means press the button the receiver and the button on the bottom of the keyboard at the same time and hold them down for 30 to 45 seconds. This will revive the signal and bring it back to working condition.
If your unit is a wireless mouse and wireless keyboard then there are probably 3 buttons involved that need to be pressed and held for 30 to 45 seconds at the same time. One button on the mouse, one on the keyboard and the last on the receiver.
If you press and hold the buttons down as explained above, it will correct the problem.
Jul 17, 2011 | Logitech Computers & Internet
My maintenance light is blinking what is for? How do I reset it?
turn key off push and hold the button on the odometer as you turn the key on to position 2, after about 10 seconds the light should flash and then go out.You must hold the button till the lite goes out.
Feb 02, 2011 | 2004 Honda Civic
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    Sentry RMC-10 remote can't 'discover' my tv's code
    .there are several codes. try each one seperate.
    1. press and hold setup button until the red light stays on.
    2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
    3. enter one of the 4digit codes.
    note: if the code is valid the light will turn off if it flashes it is an invalid code.
    4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
    1.manually turn on the t.v. and hold the setup button.
    3. press and release the tv button the light will blink once and then stay on. the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
    5. press and release the mute button to store the code the light will go off.
    Aug 28, 2009 | Sentry SE-RMC10 Remote Control
    Printer won't print. amber light blinking.
    Mar 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Message waiting indicator light will not turn off keeps flashing
    Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
    1. Hit that button to show *Options List / # Setup list
    2. Press * to go into options.
    3. Use the arrow buttons or hit 3 to go into CLEAR MESSAGE WAITING
    4. Then hit 3 again to clear the message waiting
    This should resolve the blinking light.
    Nov 11, 2008 | Astra Meridian 9417 Corded Phone
    24 people viewed this question
