Disable tip over on a little buddy - Heating & Cooling
Pilot will not stay lit on my mr. heater buddy. where do i get a thermocouple for this buddy model no. MH9BX
First follow this trouble shooting guide to make sure you need one-http://www.mrheater.com/product/faqs/little-buddy-troubleshooting/ Then Amazon http://www.amazon.com/Mr-Heater-Pilot-Assembly-Portable/dp/B008DBRB8W Make sure it's the right one for your model heater.0810snp
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
Feb 24, 2015 | Mr Heater Base Camp Portable Buddy Propane...
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
Dec 25, 2014 | Mr Heater Base Camp BaseCamp Little Buddy...
How much is cost Insignia LITTLE BUDDY Child?
Amazon.com lists them between 20 and 40 depending on which assessories you get.
Aug 28, 2011 | Insignia LITTLE BUDDY Child Tracker
My chatbox in facebook is disabled how do i fix it?i need more help coming from you...:(
hi not sure if you got help with this ! go to your chat box were it says online fridnds! popout chat etc, clivk online ! ur chat is offline only (disabled) recently facebook as updqted your chat options to a limit were you can appear on/ off line to certain friends ! you can put them into a certain cateorgy also !! TIP: and when you cathegorise your buddie list you can either chat 1 on 1 or request a group chat !! hope i didnt totally confuse you now !! if i did please ask me to refine your answer hun ok ;) good luck
Aug 06, 2011 | Facebook Social Network
Slow perfomance
Copied from one of my earlier solutions:
Here are some tips for speeding up a computer:
-Remove programs from your Windows startup by pressing Win+R and typing msconfig.
-Uninstall programs you don't need
-Use CCleaner to clean up unneeded temporary files
-Disable windows services (look up a guide on Google for a list of services you can safely disable)
-Keep your software up to date.
-Look for suspicious processes in your task manager and Google them to see if they are viruses.
These tips won't help much if the slowness of your computer is caused by a specific problem like a damaged part, but they usually make your computer a little more responsive.
If you have any specific issues that could be causing this, list them here.
May 15, 2011 | HP Compaq nc6220 Notebook
My heater keeps going out. full propane bottle , but it keeps shutting itsef off i have tried it both with 2 full cylinders , and a 20# bottle ,
look in back of the heater where the fuel nozzle goes. you will see a plate with a bunch of holes, the ignitor and the fan. also there is a little button with two wires on it. these wires connect to two spade terminals on the millivolt generator. its sensing bulb is near to the fuel nozzle. the other end with the gland nut goes into the main valve body. when the heater is on, the flame hits the millivolt generator and makes a very small DC voltage which goes through the little disk [an overload] then to the main valve solenoid. if the millivolt generator is good then there is a voltage at the main valve solenoid and it keeps the valve open. in your case it seems 1) the overload is open 2) the generator needs to be replaced. please go to desatech site and order a new generator.
Oct 24, 2009 | Mr. Heater Mr Heater Portable Buddy...
No propane comes thourgh pilot on mr buddy heater
If the pilot will not light get a q-tip and alcohol and remove the wire grill and be sure the cotton doesn't come off the end of the stick wet the cotton with the alcohol and twist it and push it down into the pilot tube 2 full inches. Let the alcohol soak for 30 seconds and while twisting pull the q-tip out. Try this until the pilot lights.
Jan 01, 2009 | Mr. Heater Mr Heater Portable Buddy...
Acer optical device driver lock
elock service, disable it
start -> run -> type in services.msc find elock service from the list and disable it by right click properties startup type disabled and click stop.
this works with some elocks not with all.
Nov 18, 2008 | Acer Aspire™ T180 PC Desktop
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
