Question about Midea Refrigerators
Midea Freezer WHS-502FWEW1 display is on but will not allow temp setting adjustment or any other function. The door open alarm works and the temp is set at -18. That is all I get. Is there a reset?
  • 1462 Answers
SOURCE: got an american whirlpool fridge
may be a indication only but on many fridge-freezers, 2 flashing lines ,means power interuption
Posted on Sep 17, 2008
SOURCE: whirlpool frost free tropical, seems
Check the sensor in the refridgerator... on the right,,
Posted on Sep 22, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
SOURCE: Our French Door model after almost 2 yrs pops open
We solved this problem by replacing the plastic parts on the top & bottom of the door that 'latch' the door closed.
On the top of each door is a white plastic 'cam' that latches into a receiver at the center point of the refrigerator chamber. One of mine was broken.
Additionally, on the bottom edge of each door is a white plastic hook-shaped 'stopper' that provides spring tension. I replaced both of those and now all is happy.
Got the parts from RepairClinic.com
Item #: 1266811
Description: Door hinge cam (left)
Price: $2.40
Item #: 1266810
Description: Door hinge cam (right)
Price: $2.40
Item #: 1267543
Description: Stopper,door
Price: $2.40
Posted on Oct 31, 2009
heatman101
  • 43501 Answers
SOURCE: fridge freezer not keeping temp
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 27, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 03, 2015 | Refrigerators
Refridgerator beeps
Apr 19, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Apr 10, 2015 | Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Beeps about 6 times when fridge door is opened.
Mar 11, 2015 | Refrigerators
Keeps beeping without stopping
Mar 09, 2015 | Smeg Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Refrigerators Logo
32 people viewed this question
Top Midea Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Midea Refrigerator Expert? Answer questions, earn points and help others
