Question about Flotec Plumbing
Looking for Flotec FPSE9050.can you check inventory? thanks
I have a Flotec 1/2 hp jet pump. Is it posible to get just the pump housing. Mine froze cracked the housing?
Use Google and put in Flotec parts.
I did that and several parts dealers came up.
Pick one and put in your model number.
I'm sure you can find a housing, the pump that I looked at had one available.
Gary
Jan 29, 2011 | Flotec 1/2hp Cyclone Pump
My dog chewed the power cord off my FPOS1800A-08 submersible pump, From whom do I order a new cord.
After searching, a clear answer was found ... if the cord replacement exists, it costs a lot.
Flotec has a contact-us form that requires your personal information
http://www.flotecpump.com/
That being said, flotec FPOS thermoplastic sump pumps have pdf parts list.
Parts list shows cord as replacement part.
However, I don't see the FPOS1800 listed
http://www.flotecpump.com/pdf/FP0S6000A_08ReplacementParts.pdf
Flotec sell sheet shows FPOS1800 but does not show parts
http://www.flotecpump.com/pdf/Pg_6_2006.pdf
Website below sells flotec parts
http://www.pumpagents.com/FlotecPumps/flotec-pump-part-list.html
Random cordset price-check shows $46 for a cord
Another cord was $80
Another cord was unknown
Nov 14, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Looking for shift sell for Flotec: FP5162
I've never heard of a shift sell for a flotec water pump. That is if you are looking for a part for a Flotec sprinkler pump. Maybe you're looking for a shaft seal.If you need parts or a manual you can look at www.flotecpumps.com The flotec part number for the mechanical seal and gasket kit is:5PP5000. You can search their web site for local suppliers, I'd call first to see if they'd have part in stock. Follow directions when installing. Do not use oil or grease to lube new seal. Liquid dishwashing soap is best.
Jul 12, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
Pump quite working
Start by checking float switch
Jan 09, 2010 | Flotec 1/4 Horsepower Sink Pump System
Can i replace the motor only on a fp4112 pump.and if so where can i get one. thanks Tim
I had a similar pump some time ago, with an AOSmith motor on it. Check your motor type and model/frame size and shaft size (which should be on the data plate). WWGrainger (check your white and yellow pages, or on line at WWGrainger.com ) for your motor. A quick check on Ebay with a search for 'flotec' showed 2 pages, but not exactly what you're looking for. Check there, and look in their 'stores'. You may also find one there. I bought my motor as a rebuilt unit through my local well and pump supply. Check there too. May save you some dinero. My rebuilt motor lasted a long time, as good as a new one.
Best regards, --W/D--
Aug 04, 2009 | Flotec Corrosion Resistant Shallow Well...
Pool pump not working
there would not be a fuse if this has a reset button I would suggest you return to company you got it from and have them replace the defected one thank you
please rate me
Apr 19, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
How to clean a sink flotec pump
It sounds like the float is stuck. Try pulling the wires coming out of the tank(shake them a little) and see if that will free the float and shut the pump off
Kurt
Apr 04, 2009 | Flotec 1/4 Horsepower Sink Pump System
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Jan 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Plumbing Logo
105 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
