How do i get a manual on a Recoton FM 100 antenna ?
    Top Expert:
  • Audio Player... Master
  • 8,213 Answers
There is no electrial retailer in bendigo that has fm aerial to suit this is why i am asking you
Make your own.
  • How to Make an FM Antenna: 8 Steps (with Pictures) www.wikihow.com/Make-an-FM-Antenna
    • 832K VIEWS
    2016-01-11 · How to Make an FM Antenna. Improving the reception of commercial FM radio (88Mhz - 108Mhz) can be done by you at home, simply by replacing the antenna ...
  • Simple FM Radio Aerial - Robert Sewell www.robertsewell.ca/yahoo/fmaerial.html Simple FM Radio Aerial A simple FM radio aerial can be made using about 5 feet of old 300 ohm TV downlead, an alligator clip and some hook-up wire.
  • Or try Jim
  • Antenna Installation Bendigo
    May 23, 2016 | Audio Players & Recorders
    Rca rt 2770 programming. My fm radio stations
    You can manually program a station by pressing AM/FM to get to the correct radio band. Then tune in a station with the Tuner +/- (the left/right arrow) buttons on the remote. Next press Memory (just below 7) and then a number on the keypad. The number must be entered before the Program Preset number stops blinking. (For FM you can use some 2 digit numbers.) To scan through the stations in memory use the Channel +/- buttons on the remote or the Next/Previous track buttons on the RT2770. You could fill all of the memory slots automatically by pressing and holding the AM/FM button for two seconds. The unit will store the stations that it tunes in in order until the memory slots are full. Note: you do need to have the FM antenna and AM loop antenna connected (and extended for the FM antenna).
    Retrevo has the manual for the RCA RT2770 available here: http://www.retrevo.com/support/RCA-RT2770-Home-Theater-Systems-manual/id/2869dj191/t/2/ . You will need to enter a code to download the PDF.
    I hope this helps.
    Apr 30, 2014 | Audio Players & Recorders
    AM on Radio does not work
    in big city , sure, FM can be strong there and AM weak.
    if the antenna is disconnected. FM can work and not AM.
    (depends on what city !)
    easy check plug in a 12 long stripped end wire and connected
    it to radio, Antenna, port, AM works now, radio good,
    no? no stations near or radio bad.
    post location and answers get 100% better, not one post ever does but be the first. i can look up what stations are in your town. no kidding.
    Nov 27, 2013 | 200-10-7004 Grille Guard Ford Expedition...
    Sanyo dcx686 am/fm amp receiver no fm reception
    you should be able to hook up any am/fm antenna, like the new ones that come in a square and hook it up to the two left-most spots for a radio antenna, thats how i have mine. as for the manual, you can order them off of a site(if you can find a reputable one) if you search SanyoDCX686 on google. hope thats somewhat helpful =]
    Dec 14, 2011 | GPS
    Need info on a Recoton Antenna -need to know DC imput amt etc.
    that coaxial cable with male end has to be connected to '' tv antenna in '' connector of your tv ....... to find whether any ac adaptor is required for your indoor antenna just observe all sides of that antenna ....... if any male or female connector is there means definitely it requires adaptor ( size will be smaller then coaxial cable's male end connector ) .... click 1 st link to see whether your antenna is like that ..... if no means check 2nd link ............ once your antenna's model no is identified it will be easy to clear all doubts ....... it may require 9 volts or 12 volts adaptor ..... Recoton's universal adaptor is available ( check 3rd link ) ...... so check these links & tell us .... then we can find exact details of your antenna .......... if possible take picture of your antenna (all sides) & email to me (sathyavijayasarathibabu@ymail.com ) ....
    http://www.orbitcommunications.com/cyberstore/product.asp?PID=TV-800
    http://www.google.co.in/search?tbm=isch&hl=en&source=hp&biw=1024&bih=527&q=recoton+tv+indoor+antenna&btnG=Search+images&gbv=2&oq=recoton+tv+indoor+antenna&aq=f&aqi=&gs_upl=0l0l0l3719l0l0l0l0l0l0l0l0ll0l0&sout=0&sa=X&ei=Ze-2Tq7BIM7HrQf4vbjcAw&ved=0CDYQxxQ
    http://www.futureshop.ca/en-CA/product/recoton-universal-ac-adapter-ad500-500ma/80730005.aspx
    Nov 06, 2011 | Televison & Video
    FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
    If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
    What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
    Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
    Sep 14, 2011 | Denon DRA-37
    I am having very poor FM reception with my Bose Radio wave system. Is there an external antenna that can be attached?
    The power cord is the antenna and it should be stretched out straight for best possible reception. You could experiment with re-orienting the Bose, too.
    There is a threaded 75-ohm coaxial FM External connector. You could probably get a compatible FM antenna at an electronics store.
    See the manual, Page 10
    Dec 25, 2010 | Bose Wave Radio
    2007 Camry: I can't receive clear radio channel in camry 2007 ...
    if you have a factory radio, then chance are you antenna is amplified (even if you don't have an antenna that goes up in the back). The fuse for the antenna amplifier could have blown or the amplifier itself my have gone bad. It could also be your radio but, i would check those things first... Just a side note: i don't know of any stations that around me that aren't odd numbers 92.3 fm,95.5 fm,100.3 fm. Where you able to tune it to 100 fm before?
    Apr 28, 2010 | Cars & Trucks
    2007 Sonata AM radio has no sound. Hit search at 100% volume and tuner scrolls non stop. FM is fine. Antenna?
    AM is reflective, FM is not. Best reception is always FM because of this reason. Reflective AM bounces off everything - buildings, trucks, houses, power poles, etc and cause 'shadow' RF which confuses the the radio's AM tuner. However, if this condition exists ALL the time (whether you driving or in your garage), then the problem is either in the audio unit itself or in the rear window antenna (or connection to it). Left "C" pillar cover removed, you'll see the physical connections to the window antenna (it's also the rear defroster heating elements).
    Oct 19, 2009 | 2007 Hyundai Sonata Limited Sedan
    SL100 static and bad FM reception
    I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
    Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
    Good luck.
    Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
    162 people viewed this question
     Grubhead
    Grubhead
