Question about Reddy Heating & Cooling
Why does the fan squeal on my reddy heater 115 pro ?
tinytrees
  • 92 Answers
SOURCE: I have a Reddy heater pro 155.
Check all of your air filters but most likely it's the CAD flame sensor.
Posted on Jan 22, 2009
tinytrees
  • 92 Answers
SOURCE: Reddy heater 115 just turns on then shuts off
a new flame sensor is in order, if you have spark and it blows fuel then thats the answer. you can get one thet will fit from Mr. Heater for 3 bucks. the wires are different so just splice the to your old wire harness, there is no wrong way to hook them up.
Posted on Jan 23, 2009
tinytrees
  • 92 Answers
SOURCE: Pro 115 Reddy Heater
The ignitor is bad, there are still parts available from reddyparts.com very simple to install.
Posted on Jan 24, 2009
SOURCE: reddy heater pro 110 started up ok went to use it
cleaned electrodes , filter and sensor oiled fan motor
Posted on Dec 13, 2009
hardrocko
  • 1476 Answers
SOURCE: I have a Reddy Pro 115 BTU kerosene heater the fan
When you say that the fan starts then stops I assume you also mean that the burner starts and stops. If this is correct and the unit is more than a couple of years old you probably need to change the filter in the back and set the pump pressure. Both the filters and the gauges to set the pressure can be found at www.reddyheat.com along with a good explanation as to why you need the gauges. The pressure is set by bleed air pressure and must be exactly 3.5 psig. The gauge is the only accurate way to do it. The filters clog and change the pressure. When the difference is enough the unit will not run. Now with that said there are several other things which you should check. Check the fuel tank for water. Remove any you find. Remove the cover on the right side as you look at the unit from the front and remove the circuit board. Check for cracked connections. If you find any resolder them and reattach the board. That should take care of the unit and get you back to making heat. Let me know if you need anything else.
hardrocko
Thanks for using FixYa
Posted on Feb 14, 2010
Reddy heater 155 squealing while running...suggestions?
check your fan motor because it may need lubrication and also make sure your screws are tight in the top cover.
Dec 07, 2010 | Reddy R155D Utility Heater
Reddy heater pro 110 started up ok went to use it
Dec 10, 2009 | Reddy Heating & Cooling
Pro 115 manual
Dave go to www.desatech.com you can down load and print off a copy of this manual, you will need Adolby 6.0.
Jan 29, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Jan 24, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Jan 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
No fuel but ignitor comes on but no motor or fuel?
You must troubleshoot to see if the motor is getting 110 volts.
The problem could be the board *or* it could be the motor.
Dec 28, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Heating & Cooling Logo
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
