Question about Keurig Coffee Makers & Espresso Machines
Plugged Keurig 450 2.0 back in and now it won't stop dispensing
Keurig.com why is coffee not dispensing?
I would recommend looking into the needle and seeing if you have a clog. That is the biggest reason for the brewing to stop.
Feb 08, 2015 | Keurig 2.0 K550 Brewing System
Blinking blue light on water reservoir won't stop blinking
Needle port is plugged. Clean with paperclip end and run it up 1/4 into the tank to clear the debris.
Apr 10, 2013 | Keurig B60 Coffee Maker
Keurig powers up and says ready, but will not dispense coffee or water
LInes from Heater are plugged. Clean as per the manual pg. 18.
Sep 23, 2012 | Keurig B60 Coffee Maker
Platinum keurig no power
under the warranty they mist give you a new one
Apr 10, 2012 | Keurig Platinum B70 Coffee Maker
My B66 usually stops dispensing well before the cup size is reached. SOmetimes it over dispenses.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 20, 2011 | Keurig B60 Coffee Maker
My Keurig says not ready, water won't stop coming out. when it reads brewing, it stops.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jul 23, 2011 | Keurig B100 Coffee Maker
The display keeps flashing Not Ready. Water is full. I've unplugged the machine and plugged it back in. Why won't it get ready?
heatman101
May 29, 2011 | Keurig B70 Coffee Maker
Just got a new Keurig mini. Plugged it in, put in the water, closed the lid, put a cup on the plate, pushed the power button, pushed the "coffee cup" button and nothing is happening.
My wife's mini single cup B31 quit dispensing hot water into the K-cup. It would go through every stage and the pump came on but no water, no coffee. Try this: unplug the unit, take the drip tray off and lay the Keurig on its back, with the top opened so you can see the dispensing probe and the rubber ring that seals to the top of the K-cup. The dispensing probe is sharp, with two small channels, one on each side. (Be sure you can spill a little water when you try this) With a kid's water blaster, or a rubber bulb, squirt water up the channels on each side of the probe. Do this a few times, then try to run it normally.
That worked for me, and loosened the few coffee grounds that were plugging the outlet.
Mar 14, 2010 | Keurig Coffee Makers & Espresso Machines
Does not dispense water unless you pinch vent in water tank.
If your Keurig is putting water out the vent and back into the reservoir. Open the front, using a flashlight and a toothpick, clean the coffee grinds out of the little hole in the needle that pierces the K cup. When it becomes clogged with grinds the water either has to come out the vent or the coffee maker will burn out. It is a safety mechanism.
Feb 28, 2009 | Keurig Elite B40 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
