Question about Keurig Coffee Makers & Espresso Machines
Keurig 2.0 won't stop dispensing water - Keurig Coffee Makers & Espresso Machines
  • 28 Answers
SOURCE: my keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Posted on Feb 07, 2010
heatman101
  • 43501 Answers
SOURCE: Keurig is B66 have had
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
SOURCE: keurig is not dispensing enough water properly
keurig is not dispensing enough water properly when making a regular cup of coffee
Posted on Aug 25, 2011
heatman101
  • 43501 Answers
SOURCE: my Keurig says not ready,
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Posted on Sep 03, 2011
donnablond46
SOURCE: The water gets hot in my Mini Keurig, but will not
I AM HAVING THE SAME PROBLEM, AFTER 3 USES!
Posted on Nov 15, 2011
I have a Keurig 2.0 that I received as a gift two years ago for Christmas. Just yesterday, it stopped dispensing any water. Everything seems normal.
your Keurig is probably clogged...lift up the latch and see where the coffee drips down..use a small object such as a needle and go up into the area where the water drips out and swirl the needle around..this should loosen the stuck grounds...
Oct 16, 2017 | Keurig Coffee Makers & Espresso Machines
GE refrigerator water dispenser won't stop after lever released
water valve in dispenser in bad,, check with store for possible replacement ,,or maybe the shut off valve isn't open all the way in water line connection
Jan 20, 2013 | Refrigerators
Keurig coffee maker won't stop, end up with 4 cups all at once
Timer section and valves open due to incorrect assignments. Replace or repair.
Sep 16, 2012 | Keurig B100 Coffee Maker
My Keurig says not ready, water won't stop coming out. when it reads brewing, it stops.
heatman101
Jul 23, 2011 | Keurig B100 Coffee Maker
I have similar problems to a number of others here do- the water does not always heat up, it stops dispensing the water, it makes a loud vibrating noise, the water sprays out in all directions and it is...
They replaced my entire unit when my heater stopped working and the unit would auto power off after trying to heat up the next batch of water. I would contact Keurig and see what they will do for you.
Contact info from their website.
Phone:
1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week Fax:
1.781.245.1869 Mail:
Keurig, Inc.
At Home Customer Service
55 Walkers Brook Drive
Reading, MA 01867
Feb 06, 2010 | Keurig B60 Coffee Maker
Does not dispense enough water. I get about 2 ounces of coffee at a time. How do I adjust the water level?
When was the last time the unit was descaled? A build up of scale will gradually restrict and then stop the water flow.
Feb 02, 2010 | Keurig B100 Coffee Maker
Coffee Makers & Espresso Machines Logo
2,534 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
