Question about HP Office Equipment & Supplies
How do I use the copy function, on my HP 5740e all-in-one printer?
    Top Expert:
  • HP Master
  • 8,204 Answers
Hp officejet 4500 printer driver
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Aug 13, 2012 | HP OfficeJet Office Equipment & Supplies
HP copy function 'device not responding or is disconnected'
Did it work at all once you reloaded the software? Is the computer recognizing it in devices and printers? If it is present, right click on the printer, go down to properties and troubleshoot.... Let me know
May 11, 2017 | HP Officejet 5610 All-In-One InkJet...
HP J4680- change copy settings so printouts are fast draft
Change settings and copy from HP Solution Center
  1. Open HP Solution Center.
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Solution Center .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: Click the Start icon (c01319360.gif ), click All Programs , point to HP , and then click HP Solution Center .
  2. Click Make Copies . The Copy window opens.
  3. In the Paper section, click A4 on the Size drop-down list.
  4. In the Start Copy section, click Black or Color .
  5. In the new window you can also change the copy settings
Jun 21, 2009 | HP J4680 Office Jet All-In-One Printer
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
May 03, 2009 | HP OfficeJet D135 All-In-One InkJet...
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
Disable copy function in hp lasejet 3055
You don't want to be able to make copies?
The only way i know is to get rid of the machine, and buy a printer.
Problem solved.
Seriously, you can't program a user code or limit access to this machine. You'll need a different model.
Mar 25, 2009 | HP LaserJet 3055 All-In-One Printer
Canon Canoscan LIDE 30
For some reason, there are some HP model printer drivers that cause problems with the Copy function of the CanoScan Toolbox. Because of this conflict, when Toolbox Copy function connects with the printer driver, which is what it is doing when you select it from the dropdown. There had been some updates to the Toolbox software that corrected the issue. However, then HP release some new drivers for some models that reinstated the issue.
So the first thing to try would be to download and install the most current version of Toolbox for your scanner model (ver. 4.1.3.5).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6623
If the problem isn't corrected with that, then you won't be able to use the COPY function unless HP updates there printer driver to correct the issue. If you really must have the COPY option, then you might try using a older Toolbox just for that feature. If that is a consideration, then get the Toolbox ver 2.2.3 from the CanoScan N650U download page.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6858
The COPY function from this version should work fine with the HP printers.
Good Luck.
Apr 28, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
HP DeskJet F380 won't copy
If you can't get it to scan an image then you might have to have it brought to a repair center. How often do you use the copy function? Scanning function?
Mar 27, 2008 | HP DeskJet F380 All-In-One Printer
Cannon scanner D1250U2F and Hp photosmart printer 8250
This is a compatibility issue between the Copy function of Toolbox and the specific HP printer driver. The only work-around would be to scan your image and save it, then print it from another application. One other possibility would be to get Toolbox version 2.2.x from the N650U scanner download page. This version will be limited in functionality, but COPY button should function as expected.
Apr 28, 2007 | Canon CanoScan D1250U2 Flatbed Scanner
Seeker5211
Seeker5211
